RCSB build
#113
Thanks dude.
In the interest of weight savings, I also picked up a pair of these little things!
![](http://www.crutchfield.com.edgesuite.net/pix.crutchfield.com/ImageHandler/fixedscale/400/300/products/2003/575/x575RFP4406-f-2.jpeg)
I've had one for several years as my computer speaker subwoofer and its very impressive. I figure two of them in a proper enclosure behind the seat with a small amp will save me space and weight
![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
#115
Yeah I should spray the shot on startup to lean it out a bit, huh... ![Icon Lol](https://www.performancetrucks.net/forums/images/smilies2/icon_lol.gif)
Does anybody know if 2004 upstream O2 sensors interchange with 2008 upstreams? This is the best lead so far in my attempt to get this thing running lol. They are the same connector, so I didn't even consider the sensor compatibility when I was putting it back together.
#116
I'm not sure about the o2 sensor interchangability but i will say you've got a seet build on your hands and im ready to hear/see it run.. You work pretty quick too..
Good luck
Good luck
#117
#118
If they have the same plugs you might as well plug em in and try it out. Worst thing thats going to happen is it'll still give ya the same rich problem from the plugs not reading correctly.
Which turbo blanket is that and are the underhood temps manageable with it?!
Looking good so far buddy. Goodluck on the o2 problems!
![Chug! Chug! Chug!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_chug.gif)
#119
Looking good so far buddy. Goodluck on the o2 problems!![Chug! Chug! Chug!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_chug.gif)
