RCSB build
Old 12-23-2011, 02:44 PM
AndysC3's Avatar
your not done with this thing yet? Ill have my Procharger on by the time you finish. Hurry it up. lol
Old 12-23-2011, 07:53 PM
milkey57's Avatar
Im ready to see how this turns out.
Old 12-23-2011, 10:51 PM
Slowest turbo build ever!
black00chev's Avatar
What a/r is the S480 youre running??
Gonna be badass with 4WD.
Old 12-23-2011, 10:56 PM
Mod with training wheels
smokeshow's Avatar
Its the big 96mm wheel in the 1.32AR housing. Lag shouldn't be too bad with the quick spool and 50 shot though.
Old 12-27-2011, 11:20 PM
smokeshow's Avatar
Anybody ever had a trans that refused to separate from the engine? I've done everything short of hitting the dowel pins with a torch... PB blaster is quite flammable. Haven't had much of a problem with rust til now. Even lifting the trans up and dropping it repeatedly does nothing to break the pins loose. Its on there pretty good...suggestions?
Old 12-28-2011, 12:31 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Go back to the gym & demand a refund.
Old 12-28-2011, 12:54 AM
Custm2500's Rude Friend
1FastBrick's Avatar
Old 12-28-2011, 01:01 AM
1FastBrick's Avatar
Seriously though, Are you sure you got every bolt???
I am not afraid to admit that I have missed a bolt while tring to remove transmissions from various vehicals. it happens...
Old 12-28-2011, 01:04 AM
Basically, it's just corrosion making the bellhousing stick hard to the alignment dowels. Shoot some penetrating oil on the dowels, and walk away from it for a while. Then come back and give it hell. You may need a second person to get a prybar between the engine & bellhousing while you shake the tailhousing all around, but it will come apart.
Old 12-28-2011, 01:09 AM
1FastBrick's Avatar
ya but corrosion that bad In AZ??? In AK I would believe it. Same with back east. I have seen some pictures of cars from the rust belt area and it's no wonder any thing survives in those areas.
Quick Reply: RCSB build
