RCSB build
Old 02-19-2012, 01:29 AM
  #261
N/ALS1's Avatar
Damn that sucks. In for reason of failure.
Old 02-19-2012, 08:34 AM
  #262
MASS seller approved
mitchellmade's Avatar
nice run
Old 02-19-2012, 09:29 AM
  #263
Laid Back
Beatdown Z's Avatar
Sucks the 6.0 died, but I can't wait to see how the 4.8 does with the weight and drag of a 4WD truck.
Old 02-19-2012, 10:02 AM
  #264
I have a gauge for that
Atomic's Avatar
Originally Posted by smokeshow
Turns out the bearings and crank didn't play nicely, so the 6.0 has to come out for a full teardown/rebuild. Can't say why just yet, but improper lubrication looks to have played a part in its demise. Funny thing was the only sign of problems was low oil pressure. It made no noise out of the ordinary.
In the mean time I will be temporarily be jumping on the stock 4.8 bandwagon with foose04 and Most Hated, so the truck won't be benched while I rebuild the 6.0
exactly what happened to my 408
Old 02-19-2012, 10:05 AM
  #265
foose04's Avatar
Saddle up, we got this!
You told me you wanted to keep your other stuff in place. That big damn S480 isn't in a t6 1.32 housing with a 96mm turbine is it? Even the 1.10 is going to be rough. I hope you have the 83 turbine and a good bottle heater, then we can get it moving out the hole.
Old 02-19-2012, 10:11 AM
  #266
f4tal's Avatar
My buddy's 370/PT88 setups did the same thing. Ended up being a spun bearing. Stock 4.8 seems like the way to go these days. Building motors are a thing of the past... hahaha
Old 02-19-2012, 10:52 AM
  #267
Ph.D. in HUBRIS
custm2500's Avatar
Defiantly a sleeper. Did it dead hook? Didn't hear any spinning but that is amazing for it to hook event in 4wd!
Good luck getting the engine back together soon.
Old 02-19-2012, 10:54 AM
  #268
Mod with training wheels
smokeshow's Avatar
Yes it is the 96mm. It will be a frankenstein truck like I said...should still be fun, though. I don't go to the track for bracket racing so I don't need to build boost on the line in any short amount of time.
Old 02-19-2012, 01:50 PM
  #269
foose04's Avatar
That's huge man...Not the compressor side, but the hot side. I bet you had a little lag with the 370.
I'd like you to enjoy it some while your getting rebuilt, but that hot side is past what I would consider drag only.
Old 02-19-2012, 02:24 PM
  #270
smokeshow's Avatar
It does have a quick spool valve, so the lag wasn't too bad. Will certainly be a bit worse with the 4.8, but I can deal with it. If I had a manual transmission life would suck with that hotside...
Quick Reply: RCSB build
