RCSB build
Old 02-26-2012, 05:40 PM
  #301
Mod with training wheels
smokeshow's Avatar
I did plan on pushing it pretty good...need a new game plan now though. Strokers can have more side loading, shouldn't see that on a 6.0 though.
Old 02-26-2012, 06:13 PM
  #302
I have a gauge for that
Atomic's Avatar
Reminds me of the phrase, "just because you've been doing it for 30 years doesn't mean you've doing it right"
Old 02-26-2012, 06:33 PM
  #303
smokeshow's Avatar
Lol no kidding...
Old 02-26-2012, 06:41 PM
  #304
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Unfortunately relying on experienced people got me broke and two stroker motors that burnt oil. It's almost like you have to become an expert in whatever you do because the experts aren't worth a ****.
Skirt damage is why whenever someone talks about doing a stroker I tell them to do it in an aluminum block due to the longer cylinders. Yours looks like its just a victim of poor machining and if you haven't already done it, its a good idea to radius the bottom of the cylinder walls.
Old 02-26-2012, 07:47 PM
  #305
smokeshow's Avatar
Couldn't have said it better myself. Haven't dug in real deep measuring yet, after seeing the pistons I figured I was already pissed off enough for today. Back to the 4.8 idea now...not sure what I will do with the 6.0 hardware yet. Probably take my sweet *** time hunting for a good machining shop and build it into something else.
Old 02-26-2012, 09:45 PM
  #306
Atomic's Avatar
Brian at LME has been good to me...
Old 02-26-2012, 10:13 PM
  #307
53RUSSELL's Avatar
How does the cylinder walls look?
Old 02-26-2012, 10:21 PM
  #308
MASS seller approved
mitchellmade's Avatar
sorry to see those pics ... I Worked at a machine shop for 6 years that built a high percentage of dirt oval motors ... pistons didnt even look like that after a full race season and those guys dont let off the pedal unless they wreck or grab the checkered for 20 laps at a time !!! I would throw the worst piston through the front window of thier shop!!! Too bad your so far away I would give you an 07 4.8 to use until your 6.0 was done so you didnt have to change your harness set up .. good luck man Your better than I , because I would have been locked up
Old 02-26-2012, 10:28 PM
  #309
only pistons that I have seen "grow" that much would be a hyper and if that is from piston rock ( which is exactly what it looks like) I wouldnt expect that unless stroke was 4" or higher and nitrous Fck that place. Sorry but that sht pisses me off . What was your ring gaps? were all the cylinders consitant?
Old 02-26-2012, 10:33 PM
  #310
smokeshow's Avatar
There's some streaking on all of the cylinder walls. Nothing major, but more than there should be for the mileage.
Funny you mention that, because the guy who did mine does primarily circle track cars. I'm not sure how to even approach the situation concerning that machinist. I admit its my fault for accepting the block with that clearance in the first place, but he stood behind his work with a smile on his face. I wasn't about to challenge his judgement with 30 years of experience, but hindsight is 20-20... Anybody else ever had to bring their broken **** back to the machinist? If so, what was the result?
edit...pic of cylinder wall
Quick Reply: RCSB build
