RCSB build
#525
Custm2500's Rude Friend
If it were built by CAGRacing or custm2500 Then I might be worried.
Your the only one I have seen go through the wiring changes to convert the older set up to run the newer electronics on your own successfully. Not to mentioned helping out with the issues on Jules Truck. I am sure you have the electronics part of the system down.
As long as the vessel doesn't leak Who cares... all it's doing is containing fluid. I have seen systems made of Junk yard coolant bottles and windshield washer pumps with wiring that looks like it has already been on fire with different gauge wires crimped together to make one long wire.
I am sure it work just fine. Bring it to the track, I should be there Thursday
