RCSB build
Old 10-14-2012, 09:36 PM
  #671
Mod with training wheels
smokeshow's Avatar
Originally Posted by Atomic
Your torque always peaks so high and falls off so quickly...it points to too small of a exhaust side on the turbo(s), but last time you had the spool valve stuck closed...what are you doing with timing with respect to rpm?
I bring timing up from peak torque to redline 4 degrees. It would point to too small of an exhaust side if boost was falling off, but its not. And again, if this 85lb/min turbo could only make 300hp...well, you fill in the rest.
Old 10-14-2012, 09:55 PM
  #672
I have a gauge for that
Atomic's Avatar
Should easily make twice that...
Old 10-14-2012, 10:31 PM
  #673
sprayedenali's Avatar
Too small of down pipes you say?!? Hmm... Hahaha
That is a strange graph as even more strange that they're almost identical. Is there another dump you could go to to get a "second opinion"?
Old 10-14-2012, 11:12 PM
  #674
smokeshow's Avatar
Wasn't my suggestion... And I had to chop up your dump tubes to fix the hot pipes anyway. I will make new downpipes eventually, but not because I think they are a flow restriction. Everywhere I drive I hear the rattle from the driver side DP hitting the hydrobooster. So that will be changing.
Old 10-14-2012, 11:19 PM
  #675
Custm2500's Rude Friend
1FastBrick's Avatar
Your Turbo Encapsulator is malfunctioning...
Seriously though. What is the lift on your cam??? Is it the Low lift comp cam???
Old 10-14-2012, 11:48 PM
  #676
smokeshow's Avatar
Lift is .570". Its the Isky cam that Jarrett created and abandoned because of his faith in the triple 12 lol.
Old 10-14-2012, 11:55 PM
  #677
GFYS and STFU
Spoolin's Avatar
It would be cool if you tapped your exhaust for pressure readouts.
I agree with sprayed, you should get a second opinion! As a matter of fact there's a bunch of dyno's out here you could use!!
And then you could finish tuning my truck for meth in the process now that I figured out what was wrong with it!
Old 10-14-2012, 11:57 PM
  #678
1FastBrick's Avatar
Interesting... -
Old 10-15-2012, 12:00 AM
  #679
smokeshow's Avatar
Can't say I'm not tempted! Maybe if you ask nicely I'll set up camp in Santa Clarita for a few days this winter lol. I have been driving the **** out of my truck recently so I feel that its reliable enough for the drive now. It has gained my trust again
Hows yours running btw?
Old 10-15-2012, 12:24 AM
  #680
GFYS and STFU
Spoolin's Avatar
If you come up Dyno sessions are on me and we can hit up a couple different ones to compare between the types of dyno's!!
Actually Jarrett and I were talking today about driving down to AZ to hang out with you tools for a day or so. I'm officially off vacation on November 24th so after that I really can't say or promise that I'll be around much.
As far as my truck, it was down for about a month because of building and swapping in the 14-bolt, there were a few complications but it's in now. I picked it up from 1Fastbrick's place last week and really haven't been driving it. I think I have a few more heat cycles to do before I can start beating on it again.
There's a grinding issue I have to work out with the rear brakes but other than that my list of things to fix is getting smaller.
-Swap meth 2bar map sensor
-Fix faulty e-fan wiring
-Wrap hot parts with the wrap that a member on here sent to me.
-Swap converter to one that locks
-Tune for meth and 20psi on race gas and see what kinda dyno queen I have on my hands!
(if Jarrett can run 146mph in the quarter with this motor I hope it'll get close to 4 digits in the power department. I might need to adopt his fuel blending techniques though.)
Quick Reply: RCSB build
