RCSB LQ4/80E swap... Take two
#31
Spent some time today cleaning up the engine bay. Removed the harness, I am going to use the harness out of my old truck. It is already set up for the efans and 4L80E.
Pondering if I should pick up an ls6 valley cover. I am installing a Norris catch can this go around. Wondering if the ls6 valley cover would be a good addition.
#32
My factory firewall insulation was a filthy mess, I removed what was left of it when I pulled the engine. I installed some DEI heat barrier today after work. It should do the job and be better than nothing. I wanted to do more, but my knees are shot.
#34
It has a pivot point, tilted it up and undid the 7mm headed bolt. Then carefully pushed the harness out and removed it from the bay. I will reinstall the other harness the same way. (Hopefully tomorrow afternoon.)
#35
I changed the headlight harness this morning, my other truck had factory fog lights. I scavenged the switch and headlight harness from my other truck. I also installed the engine harness from my other truck. Then the heavy lifting started... got the engine and transmission in. Man, the heat and humidity is brutal - and the worst has yet to come. I am hoping to get more done tomorrow.
#40
Yeah, I am very happy that my father decided to buy one. He called me to go over and see it the day it was installed. I will be able to do all of my own exhaust work now.
