RCSB Turbo 365 Project
#21
PT's Slowest Truck
Nice build man, me likey FYI, IIRC, they used to refer to that color as "Corporate Blue", as most of the GM engines of the late 70's, early 80's used to come that way (77-82 maybe? ). I've considered painting my LQ9 that color, as my truck is also black, with blue accents, but the General used that color during an era when they were just figuring out how to keep emissions down and mpg's up, and the small blocks of that day were severely underpowered Still a cool color though
#22
11 Second Truck Club
#24
This is a somewhat controversial subject. H-beams are "sometimes" stronger than I beams, but hbeams are significantly heavier from every manufacturer except callies, and that I believe is because their h beams are made overseas and their I beams are made in us, which are also quite a bit stronger. There are several guys on tech running the scat I beams that are running deep in the 9's, Kyle has also been running them in his forged 5.7 and has seen upwards of 20psi on accident IIRC. The scat I beams are around 590 grams, scat H beams are 657 grams. That is a very considerable amount of rotating mass. Also, the stock ls2 style rods have been proven to over 750rwhp on several occasions, these are 49 grams lighter a piece, and a little stronger, so I am not worried. Good questions though.
#27
Yeah, the 4wd is nice on the street, which is where I spend the majority of the time, but it does hold you back a bit at the track with the weight and extra drag. And I'm sure with some good tires and a little suspension tweaking yours will be pretty wicked...and looks super sick too!
#28
Got the valve springs swapped over, the heads on and torqued down with the ls9 7 layer mls head gaskets. I could tell when I torqued these down, they felt a bit more "spongy" then the regular 3 layers I've used before. I'm assuming thats what gives it the better seal. Tomorrow I am going through the inspection of the house we are buying so may not get much done, but I would like to have this thing completely buttoned up. Still have to drill the oil return hole in the pan, inslall the windage tray, oil pump and pickup and install the front and rear covers. Then its time to start ripping the poor ol 5.3 out.
#29
9 Second Truck Club
Uploaded with ImageShack.us
This was fri night at slomoso 3400' DA 245/75/17's stock air psi, gate hitch, on straight 91 in the tank T78/1.15 on 12-13psi. Think with some wider tires and 16psi it would go easy 10.50's on 50K street tires..
