The Road to 500+ HP - 5.3 to 6.0 Swap
Old 03-19-2014 | 10:24 PM
  #31
GREENSIERRA's Avatar
Geoff is a very awesome guy to deal with
11.1 is a nice pump gas compression ratio, my new setup is 10.8 and might take a little off the head to get me 11.1.
Old 03-20-2014 | 11:43 AM
  #32
NuckenFuts's Avatar
Shift kit and oil pump ordered
Old 03-21-2014 | 08:37 PM
  #33
NuckenFuts's Avatar
Looking at a 2007 Vmax 6.0 Crew cab truck tomorrow. Seen some rust on my truck and now feel like I'm fighting a never ending battle. Would rather stick all this money in a newer truck but If the price doesnt work this project will go on in my truck now.
https://www.youtube.com/watch?v=6vnkrzACd7I#t=57
Update: This thing was a POS, Tranny going and motor making noise. Time to keep moving with my build.
Old 03-28-2014 | 12:31 AM
  #34
NuckenFuts's Avatar
Got almost all parts in, Rods/pistons/flywheel going to get balanced tomorrow.
COMP Cams GM LS Series Retrofit Trunnion Kit Done
Started to port The intake to work better with my 102MM TB.
Plan is to build the motor Next weekend
Old 03-28-2014 | 12:43 AM
  #35
Badlands's Avatar
Looks like the build is coming together good. I want to build one for mine in the near future, hell my girlfriend wants to build a 6.0 for her truck too. Great way for a couple to bond haha. I'm looking forward to seeing what kind of power you put down.
Old 03-31-2014 | 09:02 PM
  #36
NuckenFuts's Avatar
Tranny Cooler Should keep this 60 Cool.
Old 03-31-2014 | 11:05 PM
  #37
nickleahy23's Avatar
didnt see you were from Wisco man, where at? We have similar builds going right now. Im just getting my motor put back together right now.
Old 04-01-2014 | 10:32 PM
  #38
NuckenFuts's Avatar
Green Bay, Home of the cheeseheads. Where you at?
Took Some Video tonight of the Truck as we are coming to an end with the 5.3.
https://www.youtube.com/watch?v=_-ro...ature=youtu.be
https://www.youtube.com/watch?v=WGqq...ature=youtu.be
Also Got tranny Cooler in and Engine under paint. Used a rattle can but should look better then the black/rust it was. Shift kit box got opened today but didnt want to start that till Saturday. Talked to EPS and My cam should ship end of week but starting short block this weekend.
Checked Fuel Pressure and Key on 55, idle 50, 5,000+RPM 60, So will be using the stock pump for now.
Stock Tranny Cooler
Upgraded and then light coat of black paint on it
Engine
Old 04-01-2014 | 11:38 PM
  #39
Im down in Portage. Got a few buddies who live in GB, and I make it up to most games.
Looks good. Got any closer pictures of how your mounted the trans cooler?
Old 04-02-2014 | 01:17 AM
  #40
NuckenFuts's Avatar
No, but I have to figure out where to move the air bag sensor to so can take some more in a few days for you when I pull it back apart.
What I did was went to home depot and got like a 3 foot x 1 inch flat stock aluminum or galvanized steel, was like $7. Removed the Stock cooler and cut the flat stock to fit the bottom bolt holes, you can reuse the 10mm stock bolts. The top brace you will have to predrill a small hole and I used the bigger fat screws that came with the kit and screwed the top flat stock into the core support thing. Here is My awesome MS paint skillz.
