Rob's Turbo GMC Sierra RST Project
Old 05-31-2010, 10:01 PM
  #21
makes children cry
_zebra's Avatar
i've seen a couple turbo guys go all the way back up to 3.42s
Old 06-09-2010, 12:15 AM
  #22
foose04's Avatar
Update: Posi is in, loving that! However, still not a lot of traction, but much better.
Also, strapped the truck down to the dyno:
Here's the thread with video: https://www.performancetrucks.net/fo...13#post4476613
Old 07-26-2010, 08:34 PM
  #23
foose04's Avatar
Next Update: Removed Kenny Boost-A-Pump, installed another walbro 255. Also installed stronger wastegate spring. These runs made at 15 PSI.
Video: http://www.youtube.com/watch?v=V9nRm6vZl_I
Dyno Graph:
Old 07-26-2010, 08:36 PM
  #24
foose04's Avatar
Also, the baby turbo likes it's bottle to. Added a dry shot. Started with 35 jet, then 50, now at 75jet and 15psi boost. I re-drilled my T-Stat, truck truns around 175 now. Also AIT only raise about 5 degree nows on a 3rd gear pull when spraying.
Old 07-26-2010, 08:44 PM
  #25
charcold-bowtie's Avatar
I assume you went to return style?
Old 07-26-2010, 08:45 PM
  #26
foose04's Avatar
Correct, it's be return since turbo install.
Old 07-26-2010, 08:47 PM
  #27
What did u do with wiring at the tank? i plan on putting a big external, and a hot wire kit. Just use the stock power wire to "trigger" the relay? and leave the rest of the wires hanging?
Old 07-26-2010, 10:36 PM
  #28
foose04's Avatar
I use the stock power wire to trigger a relay also. The pumps have a 8 gauge feed power wire direct from battery. The top of pump housing is drilled for the wire and 8an fuel line connection. Inside the housing is Y'ed to the two walbro's.
Old 07-26-2010, 10:59 PM
  #29
13 Second Truck Club
A Low Dime's Avatar
HAHA And you said you were going to dial back the boost once you played on 15psi and got a 600rwhp dyno........now look at you, added some nitrous ON TOP of 15psi LMAO
Old 07-26-2010, 11:12 PM
  #30
foose04's Avatar
Lol, well damnit it was sitting in my gargage and it was calling my name everytime I walked by it. Besides, I only spray it when i'm having a boring or shitty day lol. Also makes my Borla exhaust a little extra throaty when it hits!
Quick Reply: Rob's Turbo GMC Sierra RST Project
