SBC freshen up
Old 10-04-2013 | 11:24 PM
5speedsilverado's Avatar
hey i remember this truck. when i first joined one of the truck forums when i got mine i remember reading about you corvette style flip hood. glad to see the truck still around. how do you not have ac? lol when did you move to cali? i remember you lived in Prescott for a while.
Old 10-05-2013 | 12:10 AM
oakley6575's Avatar
Originally Posted by 04SilveradoMykk
Jake, good to hear from ya. Still have your SBC powered GMT800?
I still run the truck but I took the 383 out of it a few years ago. I like to experiment with different set ups. After the 383 sbc I built an LS 408 and now I'm building a turbo 4.8L This truck will go through plenty more transplants I'm sure
Old 10-05-2013 | 01:18 AM
brandon6.0's Avatar
Ant track times with old setup? Any exspectations for new one?
Old 10-05-2013 | 11:49 AM
04SilveradoMykk's Avatar
After a long tuning period I got a 14sec 1/4 down to 11.78 @118mph with a 75 wet shot.
This set up theoretically should make more, with more compression, more head flow and slightly more cam (rockers). But we'll see. I haven't run nitrous in a long time and traction has always been a problem. Also, there aren't any more drag strips in my area. They've all shut down.
Old 10-05-2013 | 12:02 PM
I'm not sure when I decided to rid of A/C, or why. My logic was probably thinking of weight.... It's also made other things like engine work, cam swaps, radiator work less involved.
I moved to Los Angeles a couple of years ago, recently I'm back in Prescott but bounce back to L.A. frequently for music or car work.
Old 10-06-2013 | 01:44 PM
Old 10-10-2013 | 08:25 AM
Rebuilt the demon, swapped over a 1.75" throttle plate from another carb. Cleaned, re-gasketed, set up for initial fire up before fine tuning.
I also opt'd to run an actual air cleaner instead of the velocity stack. I found this 10" housing in my storage. It clears the cut out in the firewall, so I ordered a 10" x 3.75" filter (1" taller then the filter below), I had trouble finding a X-Stream or similar flow thru top but in the catalogs I found a circular filter for a Suzuki that will fit nicely as a top. Also ordered a K&N velocity type air cleaner base so the airflow isn't fighting a hard 90° turn that can rob as much as 10hp.
My cowl hood was recently damaged, I have my eyes on a Cervini ram air hood. I'll need to save up a bit before making that order.
Old 10-12-2013 | 10:43 PM
https://www.youtube.com/watch?v=tjIXf4_6MYc
Old 10-18-2013 | 09:49 AM
Another 4L60E bites it. TC hub snout cracked at the weld. Clutches in trans fried.
Old 10-19-2013 | 11:06 AM
Quick Reply: SBC freshen up
