shakenfake's Sierra SLT LBZ thread (BORING)
Old 11-29-2022, 08:25 PM
  #171
shakenfake's Avatar
Received 1,278 Likes on 975 Posts
What in the old man repair is this?
Can't believe I never noticed that the first time. New battery cable coming this weekend.
You can barely see it but is that second wire coming off of it supposed to be on there? RockAuto doesn't show any grounds similar to that.
Old 11-29-2022, 08:29 PM
  #172
Custm2500's Rude Friend
1FastBrick's Avatar
can't see a second wire
Old 11-29-2022, 08:30 PM
  #173
shakenfake's Avatar
I'll take another pic hold on
Old 11-29-2022, 08:35 PM
  #174
shakenfake's Avatar
Should be able to see @1FastBrick
Old 11-29-2022, 09:15 PM
  #175
strutaeng's Avatar
Haha. One of the battery posts on my Suburban is exactly like that! Bought it from older gentleman too. 😊
I just let it be. 🤷
Old 11-29-2022, 10:05 PM
  #176
silentbravo's Avatar
My truck has that exact same smaller ground wire crimped below the large one like that. Should be factory.
I thought you were talking about the bolt with nut, which is really funny because my dad just did that exact trick while putting a battery in my other truck haha.
Old 11-29-2022, 11:01 PM
  #177
1FastBrick's Avatar
Talking
If that is the front left battery, That extra wire goes to the front of the core support mount on the frame under the front bumper. All The GMT800's are like that.
Why don't you see if that connection is bad at the battery first. You can buy the plastic cover and a new bolt if that's all you need.
Old 11-29-2022, 11:11 PM
  #178
1FastBrick's Avatar
The left front battery ground connects here with another ground from the headlight harness. But that is just a temporary bolt from when I was trying to fix the issues with my doner.
Old 11-30-2022, 12:26 AM
  #179
makes children cry
_zebra's Avatar
i initially had issues with that ground when i did my swap... sanded it down to get a better connection & grounding problem went away.
Old 11-30-2022, 12:37 AM
  #180
Unless the bare wires are corroded you probably don't need to replace it. For the ground side, it's almost better to remove the boot because corrosion builds up inside those boots and it's a lot easier to clean it with no boot, also easier to inspect the wire for corrosion. I put some liquid tape over the exposed wires on mine.
Quick Reply: shakenfake's Sierra SLT LBZ thread (BORING)
