shakenfake's Sierra SLT LBZ thread (BORING)
#471
Shift fork in the Tcase might be cracked. I cracked mine and the truck would occasionally bang into reverse. Then it just quit and would just free rev in fwd or reverse.
#472
Did some checks over the weekend.
1. Drained the rear diff and the fluid looked really good. Teeth are worn but look fine.
2. U-joints are good, no issues with them.
Then came the transfer case. Went ahead and drained it and got about a shot glass of fluid out. So I am going to guess that my problem is right there in the transfer case and it will end up needing a rebuild. I will try just adding fluid to it first and crossing my nuts though.
I did look for pump rub and I didn't see it.
1FastBrick (09-09-2024)
#474
I am looking at rebuild kits now, one thing I probably will do is get the aluminum rear half. Does anyone have a preferred vendor for that? I see prices vary quite a bit.
#476
The overhaul kit itself is a pretty standard price across the board. I probably will go with RA since I know who it is actually from. I think SKF it is like $165 which is about what everyone else is charging.
The aluminum rear half is the only thing I am not sure about. Dorman's is $400, Dirty Hooker Diesel's is $270, Merchant's is $600.
#477
Custm2500's Rude Friend
#478
DHD or Merchant?
shakenfake (09-09-2024)
#480
You most likely broke the shift fork. That wheel hop is a bitch. I hurt mine on the track and it took another year to break, this was in my lmm. They are tough but wheel hop kills them.
