shakenfake's Sierra SLT LBZ thread (BORING)
Old 09-10-2024, 07:28 PM
  #481
shakenfake's Avatar
Received 1,278 Likes on 975 Posts
@smokinlmm Did you switch to the updated shift fork?
Old 09-11-2024, 05:02 AM
  #482
smokinlmm's Avatar
I bought a used t case from Yellowchevy on duramax diesels. He just about gave it to me. There were no rebuild kits available then.
Old 09-11-2024, 07:44 AM
  #483
shakenfake's Avatar
@smokinlmm I looked at used t-cases and holy smokes they are not cheap. Rebuilding it costs a tenth of what it would be to just buy a unknown used one.
I do see that there is an updated shift fork part number. I don't really know what the difference is between the two or when/why it came out. I'll have to do some digging.
Old 09-15-2024, 03:09 PM
  #484
shakenfake's Avatar
I added fluid and no change, still same issue. I checked for codes and there are no codes. I would imagine that if this was the transmission it would feel different and also throw codes.
I've pulled the driveshafts and dc'd the electrical and skid plate. I will need to buy a trans jack before I continue.
Old 09-15-2024, 07:13 PM
  #485
smokinlmm's Avatar
Mine thru no codes as well, just wouldn’t move.
Old 09-15-2024, 07:33 PM
  #486
shakenfake's Avatar
Mine can still move.
I’d like to have it done by the weekend so I’ll know what to order.
Old 09-16-2024, 02:05 PM
  #487
shakenfake's Avatar
I found something last night that I must have overlooked when I first checked.
The entire time the truck shuddered and shook when I was reversing it felt like it was coming from behind me. I had previously gone over the brakes to make sure everything was there and working but I must have overlooked something. I found the top caliper bolt missing from the driver side bracket. I must have looked right at it and it didn't register. Which is funny/not funny because I was specifically looking for bracket bolts still being attached. I have a new bolt coming and I will refill with ATF and do a test drive on Wednesday.
Also I did not torque these properly, apparently they are supposed to be 221 ft lbs with red loctite. I only did something like 85 no loc tite. I must have misread the torque spec.
The brightside is I would never have known the t-case had no fluid in it lol
The following 2 users liked this post by shakenfake:
smokinlmm (09-16-2024), strutaeng (09-16-2024)
Old 09-16-2024, 03:42 PM
  #488
wretched73's Avatar
Ah makes sense. Always jump to the most expensive and difficult explanation
Old 09-16-2024, 03:47 PM
  #489
shakenfake's Avatar
@wretched73 I'm blind and retarded.
1FastBrick (09-16-2024), wretched73 (09-16-2024)
thebrain
03-25-2020 08:34 AM
1SICKhawk
01-05-2011 09:08 PM
CarmineSHOW
01-04-2007 01:40 AM
MNC5
13
11-11-2003 06:46 AM
Quick Reply: shakenfake's Sierra SLT LBZ thread (BORING)
