shakenfake's Sierra SLT LBZ thread (BORING)
Old 09-14-2022, 08:24 PM
  #51
100% Redneck
RedXray's Avatar
Received 1,334 Likes on 794 Posts
They day I brought her home...
The past owner nailed it with the tire shine... take my money now!
Old 09-14-2022, 09:21 PM
  #52
Custm2500's Rude Friend
1FastBrick's Avatar
I actually bought it from the used side of a local Chevy dealership. Was only listed for a day When I purchased it. 1 owner dealer serviced. Not Perfect but I fixed a few of those things right after I bought it.
Surprisingly it is the same local dealer I get my parts from. Found it online through Car Guru's. I keep looking but the only LBZ's I have found close in condition have been way Over priced....
I can do a complete LBZ drivetrain swap on this truck for the price difference. The only real difference in the trucks besides the engine/trans would be the power seats, the cluster and the shifter. Other wise its basically the same truck....
One of my old co workers has an LBZ with more mileage than mine. If he sells it or wants to trade, I may pick it up and fix it up. I would have to remove the stupid lift though... It's tried to kill him 3 times now...
Old 09-14-2022, 09:30 PM
  #53
1FastBrick's Avatar
Talking
Originally Posted by shakenfake
@1FastBrick
And yes this is the original glove box, vin matches
@shakenfake I have some bad News... I couldn't find the can right now. but my 95% is closer to 99% if I can find it. But that is the same color as my interior and No you can not have my OEM Floor mats...
shakenfake (09-14-2022)
Old 09-14-2022, 10:00 PM
  #54
1FastBrick's Avatar
@shakenfake How is this? No cleaning, no prep. Just went over what was there. I even messed up by not being patient. But I was so excited I couldn't wait to show off... It's very trans parent and took 5-6 coats... It's still wet in the Photo. You really need to do it lightly and wait between coats for best results. Other wise it will wrinkle and lift at the edges of the thinnest spots. I will fix it later... SEM 17163 is med drk pewter which is the lighter medium grey 992 or 92I
This is before.
After.
Same interior code 922
Old 09-14-2022, 10:20 PM
  #55
shakenfake's Avatar
Received 1,278 Likes on 975 Posts
Oh yeah that looks ****! Pics of tar and paint needing pieces below.
Don't mind my retard crouch
Also if this is medium dark grey will the tan floor mats be the wrong color? Maybe I need the grey ones? We'll see I think the driver side comes in tomorrow.
Old 09-14-2022, 10:36 PM
  #56
1FastBrick's Avatar
I recommend you take the top cap off to do it. Get a bucket of warm soapy water, Use a dish soap and medium to fine scotch brite pad. Remove any peeling or loose paint. The scotch brite should do it but you might need fine sand paper to feather it. Don' t try to remove the texture. Just let take the paint edge to the top of the texture. Go over the bad spots first with a light coat. It's very transparent so don't keep re applying it wet... Let it sit and dry between coats. If it starts to lift the paint just let it dry. You can go back and knock it down again after it dries. Do the black spots first and then feather out with the later coats.
The Key is light coats and patience. I can not stress that enough. It's very transparent, expect that it will take several coats and let it dry between coats. Don't try to burry it to cover it.
Old 09-14-2022, 10:44 PM
  #57
1FastBrick's Avatar
Oh, 1 more thing. If you plan on doing any real towing off the back hitch, Replace the factory hitch....
Bgbldodge (09-14-2022)
Old 09-14-2022, 11:33 PM
  #58
Bgbldodge's Avatar
Don’t end up like this guy with a bent frame. Extreme situation but a stock hitch none the less.
Old 09-14-2022, 11:45 PM
  #59
100% Redneck
RedXray's Avatar
Is that you?
It first I thought it was a 3rd grade school kid skateboarding by your new truck... my bad
The following 2 users liked this post by RedXray:
shakenfake (09-15-2022), zz454Chevelle67 (09-16-2022)
Old 09-14-2022, 11:50 PM
  #60
makes children cry
_zebra's Avatar
it was worth getting real OEM Denali lights (technically mine were from a C3) - and don't let nobody tell you they can't be cleared. them losers just didn't want it bad enough
if you'd asked two years ago, you coulda bought mine... snooze, ya lose, i reckon.
Quick Reply: shakenfake's Sierra SLT LBZ thread (BORING)
