Slow and getting slower
Old 06-19-2012, 12:54 AM
  #1001
JFOLM's Avatar
Originally Posted by Atomic
Iron 6.0 truck block, forged Weisco pistons, forged callies rods, and forged k1 4in crank machined and assembled by LME.
New injectors are done at 20psi with 55% e85...
Cool, thanks for posting.
That sucks! Good/bad thing I guess.
Old 06-19-2012, 06:13 AM
  #1002
Ph.D. in HUBRIS
custm2500's Avatar
About to get nerdy...
I made a plot of dyn cyl air versus rwtq based on my dyno runs. I found a very strong correlation with an r squared value of almost .98 using about 12 scattered data points. With this number I found my run tonight at 20psi to be around 930ftlb and 1030hp. This was a 3rd gear pull from 75mph so it was past peak torque by the time boost was fully up, but the peak hp number should be right. I'm not sure what goes into the dyn cyl air calculation but the trend holds from 100 to 700 ftlbs based on my data gathered from my dyno time.
The education it took to come to that conclusion surely cost much more then a dyno session! That is bad *** though. Have fairly solid info that you are making over 1000 hp.
Old 06-19-2012, 08:52 AM
  #1003
Lucille's Avatar
What rpm is your idle set for and what %tps does that show?
Old 06-19-2012, 09:53 AM
  #1004
nonnieselman's Avatar
Being a 1999, his TPS should be 0%
Old 06-19-2012, 03:37 PM
  #1005
I have a gauge for that
Atomic's Avatar
idle is set at 700, and yes its 0% when I let off the pedal. I still have a problem on coast down since I have a loose torque converter the truck starts to swing up and down when the speed is above adaptive idle. I think more timing should help that...
Yea...they are maxed, but im making over 1000hp to the wheels
Old 06-19-2012, 03:49 PM
  #1006
Man Motor club
rjwz28's Avatar
Old 06-19-2012, 03:57 PM
  #1007
89LS1FOXER's Avatar
come on video's!! lol
Old 06-19-2012, 04:40 PM
  #1008
TTownTech's Avatar
4 digit hp numbers your required to take me for a ride.
About to drop the 6.0 in mine planning 600whp on the bottle, now that sounds wimpy lol.
Old 06-19-2012, 07:14 PM
  #1009
Atomic's Avatar
Im gonna try to make it to holiday on thursday!
What gauges?
Old 06-19-2012, 07:24 PM
  #1010
JFOLM's Avatar
Those are good problems to have!
Quick Reply: Slow and getting slower
