Slow and getting slower
Old 06-24-2012, 11:16 PM
  #1071
Mod with training wheels
smokeshow's Avatar
Someone try sabotaging it and pouring chunks of metal in there?
Old 06-25-2012, 06:13 AM
  #1072
sprayedenali's Avatar
meh, sounds like a bad idea to me, use the shocks to tell the suspension what to do instead of putting a stop in there so you have no suspension.
Old 06-25-2012, 07:18 AM
  #1073
I have a gauge for that
Atomic's Avatar
I just bought new shocks and the problem seems to be they arent stiff enough....this mod will only cost a few dollars opposed to buying more expensive shocks.
Old 06-25-2012, 12:58 PM
  #1074
Custm2500's Rude Friend
1FastBrick's Avatar
Your going to hit the bump stops and unload the tires...
Get an adjustable shock that you can dial in.
Old 06-25-2012, 01:04 PM
  #1075
1FastBrick's Avatar
Something else just came to mind.
What about and "add a leaf" to stiffen it up???
Like an over load spring for added weight... rides like normal till you put more weight as the spring collapses it spreads the weight over the added spring and stiffens it.
Old 06-25-2012, 01:39 PM
  #1076
Ph.D. in HUBRIS
custm2500's Avatar
I would think this would be as bad or worse then a bump stop. It is a spring you will be hitting so it will bounce the rear end off of the overload spring and cause all sorts of weight shifts.
Good thing the turbo didn't suck that air filter into it's self! Had any of the mesh or screen came loose the turbo would probably be a pile of junk right now.
Old 06-25-2012, 03:03 PM
  #1077
Slowest turbo build ever!
black00chev's Avatar
Just throw some old school slapper bars on it and be done!
Old 06-25-2012, 03:07 PM
  #1078
1FastBrick's Avatar
Your adding to the spring pack, not hitting a spring.
It would there for make it stiffer.
Hitting a bump stop would shock it and unload the tires.
Old 06-25-2012, 04:28 PM
  #1079
Atomic's Avatar
I think it would only unload the tires if it were to make frame bounce off the axle. As it sits now the overload bumpers are basically lightly touching the axle anyway.
Old 06-25-2012, 06:22 PM
  #1080
Ph.D. in HUBRIS
custm2500's Avatar
I see, you are talking about simply adding a leaf. Most "add a leafs" are spaced from the stock pack a short distance so they don't effect the stock ride.
The best solution is going to be shocks, one of the few other ideas that have been discussed may be a solution and possibly save the money of buying adjustable shocks. With they money you have in the rest of the truck why skimp now? I realize if you swap the newer bump stops and it works great but anything else after that seems foolish. You haven't pulled out any stops on the build so far why half *** what allows it to put the power down?
Quick Reply: Slow and getting slower
