Slow and getting slower
Old 06-25-2012, 06:28 PM
  #1081
I have a gauge for that
Atomic's Avatar
Well this is free so lets see if this works or at least helps.
99 ones on the top, 04 on the bottom
Old 06-25-2012, 07:41 PM
  #1082
13 Second Truck Club
DV2000NJ's Avatar
If that doesn't work, what about some helper bags? Can make them as stiff or soft as you want.
Old 06-25-2012, 07:54 PM
  #1083
03sierraslt's Avatar
Hey its free, why not try it.
Old 06-25-2012, 08:23 PM
  #1084
Custm2500's Rude Friend
1FastBrick's Avatar
Send me a PM if you need me make you something special.
Old 06-25-2012, 08:33 PM
  #1085
Slowest turbo build ever!
black00chev's Avatar
This is what Ive thought about doing on my truck instead of relocating the shocks and running adjustables.
Old 06-25-2012, 11:05 PM
  #1086
Atomic's Avatar
I thought about bags when I was under there today...
I still think alot of my problem at the last track outing was the track prep. Short of using full slicks on all corners im not sure where I could go from here if all the tires are spinning...
Old 06-25-2012, 11:19 PM
  #1087
sprayedenali's Avatar
below 25psi in the tires! haha and better shocks all around... are the ones you have adjustable?
Old 06-25-2012, 11:21 PM
  #1088
Atomic's Avatar
Yes, I have them as stiff as they will go.
Old 06-25-2012, 11:36 PM
  #1089
hmm... with it bouncing and bucking like it was it definitely needs more control
Old 06-26-2012, 12:36 PM
  #1090
Smitty2000's Avatar
You need a set of shocks with stiffer valving. A stiffer spring will not solve your problem. They will prevent you from bottoming out, but your suspension will compress to the point that the springs resist any more compression just as quickly as you hit the bump stops now. You need to slow down how quickly the suspension compresses and the only way to that is with shocks that have stiffer valving. In most cases static weight of the truck should be the only factor that determines spring stiffness. Your truck weighs roughly what a stock truck weighs therefore the spring stiffness is fine.
Quick Reply: Slow and getting slower
