Slow and getting slower
Old 02-04-2013, 12:31 PM
  #1441
RoadKill03's Avatar
Very nice build. You got yourself a nice little monster. Congrats. I started using Neal Chance converters on our turbo builds and they are awesome.
Old 02-04-2013, 01:52 PM
  #1442
11 Second Club
Phantom's Avatar
Pro Torque or PTC ftw
Old 02-04-2013, 02:47 PM
  #1443
nonnieselman's Avatar
I had wayy too many problems with PTC.. customer service sucked bad! Went thru about 5 of their converters before goin to a yank.
They sent me a 700R4 converter first.. their fault
2nd one wouldnt lock up, it slipped some kinda bad even with max PSI.
3rd one worked for a lil while and the clutch went out. didnt tow hardly anything
4th time the pump broke
5th time was the "rebuilt" 4th one, installed it and it was screaming bad! Didnt even drive it. took it out and sent it back. they said it had a bad bearing in it? I had enough and they charged me a 35% restocking fee..
6th one was a Yank TT3000 till that transmission puked the output shaft.
7th time was a 4L80E
Old 02-04-2013, 03:41 PM
  #1444
I have a gauge for that
Atomic's Avatar
Which NC converter are you using? The welded one?
Im thinking for my weight I need something rated to 2000hp that wont blow through.
Old 02-10-2013, 12:08 AM
  #1445
Atomic's Avatar
Hopefully I found whats been making the underside of my engine oily...front seal is worn out, notice the right side of it. The one on the right is a new one.
Old 02-10-2013, 08:19 AM
  #1446
Ph.D. in HUBRIS
custm2500's Avatar
Does that mean you might have a bearing allowing too much movement to that side? No other reason i can think of that would allow once side of a seal to get worn.
That is assuming it was installed straight.
Old 02-10-2013, 09:56 AM
  #1447
chevrolet all the way's Avatar
thats interesting.... something hopefully is misaligned, or the pulley incident started it.
Old 02-10-2013, 11:14 AM
  #1448
Atomic's Avatar
Pretty sure the pulley walking off did it a few months ago since I never replaced it after that.
Old 02-20-2013, 01:13 AM
  #1449
Atomic's Avatar
So it turns out replacing the front cover didnt fix my mystery oil leak after all, although I think it helped. The only thing left I could think of is the oil cooler lines....the block im using to go from the engine to the lines has -10 fittings on it, which I had to step down to-8 to use with my cooler. I think one of those joints was leaking so I replaced the entire length with solid -8 line and found a new cooler block on ebay. It wasnt there last year, but I found it for $50 and it came with fittings and ports for the turbo feed and temp sensor. Its also a lot smaller than the old one.
Also my new converter from PTC came today...this thing is a beast! Hope to have it in by this weekend!
Old 02-20-2013, 09:59 AM
  #1450
Ph.D. in HUBRIS
custm2500's Avatar
Looks nice!
How long does it usualy take you out and in for the trans?
Quick Reply: Slow and getting slower
