Slow and getting slower
Old 02-22-2013, 12:33 AM
  #1471
I have a gauge for that
Atomic's Avatar
Uhh...I called him and said "Im pushing about 1200hp at the flywheel with a 4l80e in a 5000lb truck", and he said ok I think I have one that will work well for you
Mentioned it would probably stall around 3600, but I dont really care about that unless its super super loose.
Old 03-09-2013, 10:36 PM
  #1472
Bama boys need updates on your **** !!! How's the new verter?
Old 03-10-2013, 01:46 AM
  #1473
Atomic's Avatar
Unfortunately....things arent so good.
Notice some low oil pressure so I cut the filter open...
Also tested the trans, and it has low pressure in every gear, so it needs to come out as well...
But I took it to the track today to get a final run in, and this is with only 17lbs with a 12lb launch on a bummed trans...be sure and listen to the speaker
Turbo work truck Holiday Raceway - YouTube
Still runs good on a bad day!
I am hopeful though, I knew it wasnt going to last forever at this power level. Although I am bit irritated at the engine issues (I think the crank is bent...), when I get it back to 100% its going to be a beast with this converter and turbo!
Old 03-10-2013, 06:46 AM
  #1474
Gadgetized's Avatar
Damn, sorry to see that. Hopepfully it didnt put any filings in the turbo.
Do you have your mains pinned? That's one thing I didn't do that I wish I would have.
Old 03-10-2013, 09:42 AM
  #1475
TTownTech's Avatar
Sucks man, maybe it won't be to bad to get it straightened back out. Got to make some passes in my car this weekend at i22 but hopefully ill get the mini-tub and suspension done this month and ill get to come out and play with y'all.
Old 03-10-2013, 09:57 AM
  #1476
WhiteX's Avatar
I have been watching this thread from the beginning and I feel your pain every time something has gone wrong. 100% my favorite truck of all time.
Old 03-10-2013, 10:30 AM
  #1477
GMCtrk's Avatar
Truck sounded freaking great going down the track. The ladder is classic.
Old 03-10-2013, 12:00 PM
  #1478
milkey57's Avatar
Sorry to see this, but gotta say for a busted up truck she still moves the f out! Lookin forward to phase 4 or 5 or whatever you are on now too.
Old 03-10-2013, 03:17 PM
  #1479
Gadgetized's Avatar
Why do you think the crank is bent? I would check it with a degree wheel and a dial indicator before you pull it out and once you get the heads off. I assume you would have already expected to do that though.
Old 03-10-2013, 10:52 PM
  #1480
Atomic's Avatar
This is the second engine I have had this crank in that showed the exact same symptoms...low oil pressure but still runs perfect. Completely new block. I plan to check it with it still in there. Hoping to have it out this week. Just dropped off the trans at blakes.
Quick Reply: Slow and getting slower
