Slow and getting slower
#222
Well class has started back so progress will be a lot slower. I didnt get near as much done in a week as I thought I would, mainly because those seats took a day each to make the brackets.
I had to redo the 10b gearing today because I didnt get the crush sleeve completely crushed and had the most horrible noise youve ever heard when coasting at 30mph+
Heres the pattern I got after today's tinkering
This brings up an interesting thought...when I was searching the interwebs to find possible solutions to my problem, I found a lot of high-hp guys using solid spacers and shims instead of the crusher washer to get the right pinion preload. Any experts have an opinion on that?
Also I discovered the trans crossmember on my 99 is different than my 04. What this means is the crossmember I had made will not work and I will have to come up with something custom
#223
Slowest turbo build ever!
The solid spacer is really easy... Just torque down a fresh crush washer and pull it back out, mic it and make a solid spacer the same size. Did this when building the Ford 9" for my dads car. Started a thousandth or two bigger then what the crusher washer was and worked out perfectly.
#228
Mod with training wheels
If you've got a careful eye and a steady hand you can get away with reusing the crush sleeve. Just make a line of marks on the pinion, nut, and yoke and then take it apart and reassemble it. Long as the marks line back up you're good. I did that like 2k miles ago, still runs great. Up to you...I just replaced a pinion seal so I didn't really feel like ripping the whole thing apart to replace the sleeve.
#229
I reused the old one and it works perfect....gotta be careful tightening it back though. I compared them when I had it apart and the old one was slightly more compressed, which satisfied my reasoning of what was wrong. I like the idea of a solid for my 14b though, just wanted some feedback first.
