Slow and getting slower
Old 08-28-2011, 06:29 PM
  #241
I have a gauge for that
Atomic's Avatar
Thanks, remember how long they are by chance?
The bolts I have now bolt into the original flange on my axle, which is a 92. Whats the clearance between the flange and the tube? Looks tight...
Old 08-28-2011, 06:35 PM
  #242
Custm2500's Rude Friend
1FastBrick's Avatar
oh geez... I believe it was 2 and 7/8 inches from axle face to Braket face were Brake flange bolts up.
Double check my thread were I compared them with measurements
https://www.performancetrucks.net/fo...thread-467473/
Let me go find some bolts... BRB
Old 08-28-2011, 06:48 PM
  #243
1FastBrick's Avatar
not sure were my calipers are at but there is about 1 1/8 inches of actual thread. I would say 30mm I will try and get you a picture.
Old 08-28-2011, 07:07 PM
  #244
1FastBrick's Avatar
30mm of thread and 40mm long... of course the only one I can find doesn't work.
You can always have extra threads but not enough will screw you...
BTW set the pinion up 5 degrees and set the new flanges on at 45 degrees. That way your disc will then be clocked correctly.
Attached Thumbnails Slow and getting slower-imag0429.jpg   Slow and getting slower-imag0428.jpg
Old 08-28-2011, 07:14 PM
  #245
1FastBrick's Avatar
I made fitment around .010 oversized. Clean the tube with something non- agressive first to remove the scale... the tubes are not perfectly round because its a welded seem tube.
Old 08-28-2011, 07:42 PM
  #246
Atomic's Avatar
The paint I used is appearently thicker than I thought, once I scraped some off it fits perfect.
My brakes have been off 90 degrees since I reused the stock flanges, so I was just going to eye ball it to 45 degrees offset than those
Heres a pic so you guys are happy
Old 08-28-2011, 07:59 PM
  #247
1FastBrick's Avatar
get a cheap angle finder like at harbor freight its a little needle style will get the job done and its like $5
Old 08-28-2011, 08:01 PM
  #248
1FastBrick's Avatar
acttualy the originals should be 0 accross the top since they were Drum. set the other ones so the look like a roof |>
Old 08-28-2011, 08:13 PM
  #249
Atomic's Avatar
yep, thats the plan. I dont feel a need to be too exact since, like I said, they worked perfectly fine being 45 degrees off, so 1 or 2 wont be a big issue.
Old 08-28-2011, 10:07 PM
  #250
formerly b4vwannabe (2/4/2012)
badz24s's Avatar
damnit Richard, we need more pics!
Quick Reply: Slow and getting slower
