Slow and getting slower
Old 09-11-2011, 10:35 PM
  #291
charcold-bowtie's Avatar
Nice piece, I just dont see the advantage over tapping the block?
Old 09-11-2011, 10:48 PM
  #292
I have a gauge for that
Atomic's Avatar
if you mean in the little blockoff plate I already have that used for the oil feed for the turbo.
Old 09-11-2011, 11:02 PM
  #293
Mod with training wheels
smokeshow's Avatar
That would look way cleaner than tapping the oil port, IMO. Where did you get it from?
Old 09-11-2011, 11:12 PM
  #294
Atomic's Avatar
ebay, of all places
Old 09-11-2011, 11:14 PM
  #295
smokeshow's Avatar
I'll have to search around. Someone on here posted up with pics of a drilled and tapped oil cooler plate that looked pretty slick.
Old 09-11-2011, 11:38 PM
  #296
Atomic's Avatar
this thing costs $25 for billet, taped and shiny. sounds like a deal to me.
Old 09-12-2011, 08:43 AM
  #297
Ya i expected it to cost more. And yes I mean the oil port. I dont see that being "cleaner" than the other tapped block. But I could maybe see a use if your adding an oil temp sensor.
If you did put a "T" on the that everyone uses, you would have a closer value of what oil temp the turbo is seeing. But I doubt there would be much of a difference.
Old 09-12-2011, 08:20 PM
  #298
Atomic's Avatar
Correction, the oil pan thing is actually 20mmx1.5
Well at least its pretty damnit!
I finished putting the axle under truck and getting it bolted up. The spring pins from tuff country were 9/16, while the holes in the spring perch are 1/2. The perch is too close to the axle tube for me to use a step bit so I took off 1/16" of the spring pins. I feel a lot better about using the 3/8" pins than 1/4" bolts...
Also installed new suv calipers and stainless brake lines...although I think I got the left and right backwards. I think I may have welded the flanges too far back on the tube...the outside pad of the caliper rubs the rotor more than I like...I can still turn it by hand though so I am wondering if it wont wear just enough not to contact in normal situations. I made damn sure I had the flanges in the right place before I welded though
Size difference between the single piston truck caliper and dual piston suv caliper
Progress...
Old 09-13-2011, 06:01 AM
  #299
Ph.D. in HUBRIS
custm2500's Avatar
The way to tell if you have the calipers on backwards is the bleeder has to be at the top. Otherwise you will never be able to bleed them fully. If the bleeder is at the highest point you are all set to go.
If just the pad is slightly contacting the rotor it will be pefectly fine. Is there anyway to get a tiny shim to bring the caliper out? If not it won't be the end or the world like i said. The pad will wear a tiny bit and be perfect.
Old 09-13-2011, 08:27 AM
  #300
Atomic's Avatar
The calipers are on the correct sides, but I think I did the lines backwards since one is has basically no slack and the other has a lot of it. The only way to bring the caliper out is to pull everything off including axle shafts and take off the backing plate and use something to space it. These SUV rotors are 10mm wider than the stock ones so clearences are much tighter. I can still turn the rotor by hand, its just not easy.
Quick Reply: Slow and getting slower
