Slow and getting slower
Old 09-21-2011, 03:55 PM
  #331
lglowe's Avatar
Where do you get your rims widened?
Old 09-21-2011, 04:16 PM
  #332
I have a gauge for that
Atomic's Avatar
Wheels America in Dallas, Tx
Old 09-21-2011, 04:24 PM
  #333
Man Motor club
rjwz28's Avatar
Nice just wanted to make sure you weren't gonna have lurching issues. I don't ever see staggered setups on 4x4s unless they're running in 2HI.
Old 09-21-2011, 04:54 PM
  #334
Atomic's Avatar
I plan to run in 2hi about 90% of the time, but for when I dont want to spin to 80mph 4wd should come in handy
Old 09-21-2011, 08:55 PM
  #335
black04's Avatar
I hope you don't have any problems with the 2 different tire sizes. I had staggared tires on my truck that were off by .5" (265/35r22 front and 285/35r22 rear) and if I put it into 4hi the truck started to shake and vibrate really bad at 20+ mph.
I put 285/35s on the front and it stopped.
The stockers look awesome tho!
Old 09-21-2011, 09:50 PM
  #336
Atomic's Avatar
They should be very close but I am going to measure them before trying to use 4wd, obviously.
Old 09-22-2011, 06:51 AM
  #337
Ph.D. in HUBRIS
custm2500's Avatar
I learned something a few weeks back that I would have called big time BS if I hadn't heard it first hand.
Long story short:
Guy has a 4wd F-450. Had 4 new drive tires put on the rear. This past winter the 4wd was acting up and in a month or less of driving most on snow in 4wd it destroyed the T-case. He wasn't able to shift into 4wd at any speed at all.
He had the T-case replaced went to the shop who put the tires on and made them put 2 fronts. The T-case shifted normal again and all problems were solved.
Lesson learned: Tires with only a few 32nds of tread worn off were enough differance that this dually truck was un able to drive in 4wd.
Old 09-22-2011, 12:48 PM
  #338
Man Motor club
rjwz28's Avatar
That's why i rotate mine regularly. That exact reason plus I want them to last as long as possible and I get sideways occasionally
Old 09-29-2011, 04:34 PM
  #339
Atomic's Avatar
Replaced the input on the tcase yesterday, and forgot how much of a bitch that snap ring in the back is. No pump rub on the case either, but I still put in the protector ring thing, and the chain looked fine. I also played with the 4wd mechanism while I had it apart and its pretty neat to see how it actually works and what happens when you pull the lever.
Also got my spacers in and tires mounted up. I probably wouldve been fine with a 1.5" spacer instead of the 2.5", but oh well, works fine.
Check out this cali lean
Old 09-29-2011, 04:39 PM
  #340
formerly b4vwannabe (2/4/2012)
badz24s's Avatar
I see you have your bike in the bed so you must be planning on being in the bike race at junkyard
Quick Reply: Slow and getting slower
