Slow and getting slower
#542
I fixed the gas tank issue, used some 5/8" hose with a breather on it so it could vent. Also cleaned up the wiring near the battery.
I am going to have to rethink my oil cooler thing because the adapter plate I have will hit the front driveshaft...
I dont think performabuilt fixed my transmission I broke back in January...I sent it to them to fix under warranty and havent tried it out until now and its doing the same thing; no 4th gear. When it goes to shift the engine just revs.
#544
So you have to pull the trans again? Is it possibly in the tune? That really sucks if you have to pull it again.
I was in the same boat. Pulling the trans half a million times because it wasn't done right. I haven't driven my truck since it was done last time so I am anxious to see if it is fixed or not too.
#545
Yea, gotta pull it at some point if I want all 4 gears...I hate pulling transmissions. Its not in the tune.
This oil cooler thing is becoming a pain. The oil sandwhich plate deal I was going to use wont work because it hits the front driveshaft, so I got this cool piece:
Only problem is it has -10 fittings and that **** is expensive, and I just so happen to have a lot of -8 fittings and hose I am going to make work. This will also be good for my turbo feed, and oil temp monitoring.
