Slow and getting slower
Old 03-10-2012, 10:23 PM
  #651
I have a gauge for that
Atomic's Avatar
Ive posted a couple videos in the last few pages.
I fixed my fuel level sensor today since I am using an 07 tank, an 04 bucket with sensor, and a 99 truck... The 99-02s go from 40 to 250 while the 03+ go from 250 to 40 (or I may have that backwards). On top of that, the connector on top of the bucket needs two wires switched. Since I am not using the factory pump or wiring, I switched the wires to the purple and orange/black are in the middle. I also attached a 99-02 sensor to the 04 bucket so I didnt have to resolder the sensor. Works perfectly.
Worked on tuning it today...I am getting some knock at around boost entry, not sure if its real or not or what is exactly is going on. Also I get a lot of misfires which prevents the converter from locking.
Old 03-12-2012, 05:14 PM
  #652
Atomic's Avatar
So in an effort to try and figure out the misfires/knock sensor activity I pulled all of the wires and plugs to check them out. All the wires tested good, around 30ohms, and all of the plugs looked good (pic below). However, I put the exhaust gasket on the driver side on backwards so the little tab was blocking the number 1 wire from fully engaging the plug. In order to turn it around with exhaust studs I had to loosen the crossover pipe slightly, and in doing so the o-ring gasket thing on the flanges fell out. That little bastard is impossible to get in the right spot without pulling the whole thing off so of course on the test drive I had a big exhaust leak.
In putting the plugs back in I thought I cracked one due to the weird angle because of the down pipe, and im glad I checked because I did. Today consisted of buying a new spark plug and installing that, and ordering a real flange gasket, not that stupid ring thing. I am going out of town for the rest of the week so this is where it sits as of now...
Look perfect to me...
Old 03-12-2012, 05:19 PM
  #653
formerly b4vwannabe (2/4/2012)
badz24s's Avatar
dang man, that sucks. it's always something though, right?
Old 03-12-2012, 05:20 PM
  #654
Atomic's Avatar
haha yep, always something, but ill take an exhaust leak over something serious any day
Also placed my order for a new front dshaft from DSS.
Old 03-12-2012, 05:21 PM
  #655
badz24s's Avatar
true dat, true dat
Old 03-12-2012, 09:34 PM
  #656
Bumpers's Avatar
as many times as you have pulled engines in the last few years i woulda though you knew how the manifold gaskets go on
just messing with ya
Old 03-12-2012, 09:40 PM
  #657
Laid Back
Beatdown Z's Avatar
Take it easy with teh anti-seize wildman...
Old 03-12-2012, 10:04 PM
  #658
Bumpers's Avatar
Originally Posted by custm2500
You didn't install the factory style retractors on your harness? Big downside to a 4/5 point is once you are in, you are in! The few guys I know that have run them on the street only use the lap belt wile driving on the street.
A lap belt in a vehicl isnt goin to do much good.... if your in a crash 90% of the time its forward motion and a lap belt is still gunna let your upper body eat the steering wheel. The lapbelt will keep you in the seat but other than that its not gunna help much.
Are yours sewn in richard? (shoulder belts sewn to lap belt)
Old 03-12-2012, 10:27 PM
  #659
Atomic's Avatar
Yea, they are sewn together. They are the corbeau ones so they are pretty high quality.
Old 03-13-2012, 10:26 AM
  #660
black04's Avatar
damn i didnt know you could even put the exhaust gaskets on backwards. I should check mine.
Quick Reply: Slow and getting slower
