Slow and getting slower
Old 03-19-2012, 11:51 PM
  #681
I have a gauge for that
Atomic's Avatar
The "VCM scanner" as well as the "NGK_WB"? The former is the file that contains the custom PIDs.
It works for me, obviously
Old 03-20-2012, 08:41 AM
  #682
11 Second Truck Club
joeyc125's Avatar
I had the same deal with my 00 PCM, could play with timing, afr, new knock sensors and race gas all day, it still threw a fair amount of random kr all the time. I swapped to an 02 PCM and it cleared up 100%. To me, $200 is cheaper than a new engine because your PCM can't tell you true knock from false knock. Also, I tried an 02 OS with the 00 PCM, didn't help at all.
Old 03-20-2012, 08:46 AM
  #683
Atomic's Avatar
Was there any other difference besides the 02 just works better? I guess I know what I will try next if the plugs dont work...
Old 03-20-2012, 08:54 AM
  #684
sprayedenali's Avatar
I have a 01 PCM and have zero knock... There's ways around it. I have an idea of what it is but won't e able to see the log until this afternoon
Old 03-20-2012, 08:59 AM
  #685
Atomic's Avatar
Im very hesitant to touch the knock sensor sensitivity since I did that last time...
Old 03-20-2012, 10:04 AM
  #686
JoeyGC5's Avatar
My 01 pcm's operating system gave me an erratic false knock at the weirdest times. I loaded an 02 12212156 os into my 411 pcm and the erratic knock issue stopped. This is with efilive though so I'm not sure if you can easily do tis with HPTuners
Old 03-20-2012, 10:32 AM
  #687
Atomic's Avatar
Im pretty sure I would have to license whatever file I want to write to my pcm with hptuners. That means im still out the $200 with my same physical pcm. I found a few salvage yards nearby that should have an 02 pcm. If the plugs dont work, that will be next stop.
Old 03-20-2012, 03:48 PM
  #688
Laid Back
Beatdown Z's Avatar
Originally Posted by smokeshow
I did use your config. Not sure whats up with that.
Use notepad to open vcmscanner cfg and you'll see the PID's he's using.
Old 03-20-2012, 07:26 PM
  #689
joeyc125's Avatar
If I remember right, the 01+ pcms had a better processor or some type of physical improvement. Been awhile since I dealt with it, but I'm pretty sure it was more then just the operating system.
Old 03-20-2012, 10:13 PM
  #690
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Originally Posted by Atomic
Use the config files I posted. Im logging my wideband through my EGR so it shows up only as one of my custom PIDs. AFR is very close with the meth off, and rich (obviously) with it on.
Garret, yea Ive heard that, but I dont have an 02 computer nor want to pay $200 to license and apply a custom SD OS in addition to the cost of the pcm to test that theory.
Its no theory, the 99 PCMs are horrible about false knock and the 00-01s are a litte better but the 02s seem to work fine. Same thing with the 98 fbody PCMs, its a well documented issue. Just an FYI, Id hate to see you keep chasing your tail over a relatively simple issue.
Quick Reply: Slow and getting slower
