Slow and getting slower
Old 06-01-2012, 03:27 PM
  #921
Custm2500's Rude Friend
1FastBrick's Avatar
Talking
this is starting to turn into MindGamesPerformanceTrucks.net
I like it!!
Its a mind game every time I get an update from this thread....
Old 06-03-2012, 09:52 PM
  #922
I have a gauge for that
Atomic's Avatar
I got the clevis mounts for the front end straps today and got everything installed but the straps I ordered (10") are too short! Damn! I ordered some 12" that should be here sometime this week....Also have the new rear shock mounts tacked up, now I just need a better welder to finish them off.
I changed the rear diff fluid, trans, and motor oil and everything looks great. I cut open the oil filter for the engine and everything looks normal!
Old 06-03-2012, 09:59 PM
  #923
JFOLM's Avatar
Good to hear! What are you doing about the turbo bearings?
Old 06-03-2012, 10:05 PM
  #924
Atomic's Avatar
For now just letting the truck idle longer after runs, but I was already letting it idle for a few minutes so I dont know how much help that will be.
Ive started to shift the blanket over so it can loose heat easier after I park it, but I may end up taking the blanket off all together. I ordered a infared heat gun so ill see if the temp is rising after I shut it off...
Old 06-04-2012, 12:18 AM
  #925
JFOLM's Avatar
I see. I assumed they weren't salvageable.
Old 06-04-2012, 05:47 AM
  #926
GFYS and STFU
Spoolin's Avatar
Are you coking the turbo? There's a aftermarket turbo timer that you can buy that helps with that.
Old 06-04-2012, 07:18 AM
  #927
Atomic's Avatar
When I had the compressor wheel upgraded he basically rebuilt the turbo, so all the bearings are new.
I was under the impression a turbo timer just keeps the engine idling for a few minutes...which is what im doing anyway.
Old 06-04-2012, 09:10 AM
  #928
nonnieselman's Avatar
are you running an oil cooler?
Old 06-04-2012, 10:19 AM
  #929
Atomic's Avatar
Yea, a B&M 30,000btu, -8 line...
oil temps are fine, usually always under 220, its just the turbo sits there and cooks the oil after I shut it down, even after letting it idle for a few minutes.
Old 06-04-2012, 11:14 AM
  #930
Ah ok cool..
Yea i bet that dude gets hot after being run that hard!
Just throw a bucket of water on it after ever pass
Quick Reply: Slow and getting slower
