t-6 BW build
Old 08-12-2010, 02:45 AM
  #51
charcold-bowtie's Avatar
lol, I dont want them! the last thing i need to do is mess this thing up right before i move. It would be nice for some baseline raw times tho
Old 08-12-2010, 07:39 AM
  #52
JoeyGC5's Avatar
Nice project, how much clearance do you have between the downpipe and the ac components?
Old 08-12-2010, 10:56 AM
  #53
several inches, the top peice, right outa the dryer I bent some, the rest is stock. The wastgate get clost to that same hose later on, but there is an airgap there as well too, and its wrapped, and my wastegate is wrapped
Old 08-28-2010, 01:27 PM
  #54
Decided to come back and try to get the truck up to abilene. I think i have my oil leak fixed. I had a leak i thought was the rear main, I now think it was the driver valve cover, leaking at the very front runing back to the rear of the motor, down and into the 80e inspection cover. But im really not sure yet, also have a new leak around the turbo drain. sigh.
Old 08-28-2010, 02:05 PM
  #55
Resident Retard
BlackGMC's Avatar
Keep at it man, you will get there eventually
Old 08-28-2010, 02:18 PM
  #56
Still leaking, gonna pull the passenger, then i may pull the intake to look at the valley cover. I have a lot of oil coming from somewhere,
Old 08-28-2010, 04:51 PM
  #57
Resident Retard
BlackGMC's Avatar
you didn't have the oil issue before you installed the kit?
Old 08-28-2010, 05:55 PM
  #58
Ya i think It had a drip, but nothing like it does now.
How much oil can a dipstick tube leak if not seated properly? im thinkin that may be my problem, I checked both valve covers today, The oil seems to originate near the starter area, but above the turbo drain, im thinkin it may be running down the creases of the pan, to the inspection cover, dripping right behind the oil plug. At WOT, its moving some serious *** oil tho.
Old 08-28-2010, 06:18 PM
  #59
9 Second Truck Club
tarinitup's Avatar
It can leak out a shitload of oil through the dipstick hole. Mine shot oil and stained the whole inner fender at the track once.
Old 08-28-2010, 09:05 PM
  #60
well it drips at idle, right from here.... Seems to originate above the starter. Pretty frustrated with it. Any good opinions is wanted.
How many O rings are on the dipstick?
It drips by the drain hole in the inspection cover.
Quick Reply: t-6 BW build
