Tired Out '00 Ecsb Z71 Turbo Project/Build/Whatever
Old 08-30-2012, 07:24 PM
  #121
Slowest turbo build ever!
black00chev's Avatar
Well 5 days after I placed my order, Amazon finally shipped out my wheel hub today and will be here tomorrow. So hopefully I can get that done this weekend or next. Which will allow me to get going on dropping the truck another 2" and alignment soon.
Also did a couple little things for aesthetics. Replaced the corner light marker bulbs with amber ones(since there are no yellow reflectors now and didnt match the turn signal bulbs) and also replaced the factory DRL bulbs with Sylvania Silverstar bulbs. These things are BRIGHT!!! They have a light blue tint on the bulb but the burn pure white, not the slight yellow that the clear bulbs do. Think im going to go back and pick up some matching low beam bulbs tomorrow.
Old 09-17-2012, 06:21 PM
  #122
Not really an update but just want to bump this up. Justin won't be in my area to tune again until the end of October, so I wont get the trans parts installed until sometime after the first weekend in October. I dont want to take a chance of having the trans fail. Going to replace my hub and do an oil change tomorrow, as well as put on my "winter" wheels with 265/60-18 tires. I feel like this bad wheel hub is slowing me down ever so slightly and with the 285/50-20s im running now, the best Ive ran is a 10.11. Will be hitting the local 1/8 mile Wednesday to see if I can pull off a 9.9 or better in 4WD finally. If I can I'll be content until spring time. And Im REALLY hoping by then Ill be close to getting the turbo stuff done. Its been a long time coming, but Im a believer of doing everything right the first time. No matter how long it takes .
Old 09-17-2012, 08:15 PM
  #123
LOBO2's Avatar
I hope you hit your 9's man. I know how you feel I'm chasing them too (10.39 1/8).
Old 09-17-2012, 08:22 PM
  #124
Thanks man!
My previous best on the smaller wheels/tires was 10.13. But that was with a bad fuel pump and regulator. Ive since replaced both (new pump is a 255 walbro) and got retuned for the adde fuel pressure. Managed a 10.11 with the larger tires after all that (previous best on larger tires was like a 10.2x something). So im feeling pretty confident I can knock one out!
Old 09-17-2012, 08:53 PM
  #125
LOBO2's Avatar
Originally Posted by black00chev
Thanks man!
Yeah I agree, you should hit the 9's with no worries at all.
Old 09-18-2012, 05:33 PM
  #126
Ill be happy if I do that's for sure!
Got the new hub put on today. Old one felt like it was full of sand when you turned it. Also changed the oil. Just gotta swap out to my smaller wheels/tires and hopefully tomorrow I'll get my 9.99 or better ET (in 4WD).
Old 09-19-2012, 10:24 PM
  #127
Well guys I did it! I finally got into the 9s (1/8 mile)!!!
I also managed to do it on my 20" wheel/tire setup. Wasnt able to run my 18" wheel/tire setup due to a couple valve stems dry rotting over the winter and wouldnt hold air.
Here's a link to all the details in the Drag Racing section since I dont feel like typing it all out again.
https://www.performancetrucks.net/fo...1/#post4993781
Old 09-20-2012, 02:32 PM
  #128
LOBO2's Avatar
Hey, hey, hey!! Congrats on the 9's man!!
I know it had to feel great when you got that slip and saw the 9 instead of a blasted 10!
Old 09-20-2012, 07:18 PM
  #129
Hell yea it did! My second best time of the night was my very first pass... Doesnt get much more exciting than that!
Parts update
Ordered these very well put together little guys last week from Brian (supercharger connection). Ive got to say these are the best spark plug wires Ive ever seen.
I also couldnt pass up on a Spectre CAI for my S10 that was $150! Got this PITA put on today. Very nice kit, but the old crap sucked getting out of there and the fit of the new intake wasnt quite perfect but not too bad. Hardest part was getting the IAT sensor in through the grommet. For the little 2.2L that my S10 has, this kit makes a nice difference from 2500rpm and up.
Old 09-22-2012, 10:47 AM
  #130
LOBO2's Avatar
Those plug wires do look good. Are they truck specific or did you just get them for a LS engine?
Quick Reply: Tired Out '00 Ecsb Z71 Turbo Project/Build/Whatever
