tt 427lsx tbss build
#22
So found a bent reluctor wheel, so back to machine shop to get it replaced. Went ahead and opened up the ring gap a bit just in case I wanted to run something crazy like 30 psi
Also, used this time to get everything powdercoatd wrinkle black for extra stealth.
#27
I meant if you literally just give someone a crankshaft and ask them to replace the reluctor wheel... not do all of the work and re assemble it.
#28
I would be interested in picking your brain on the what I should consider when building my primaries for the twins.
#29
I would say it probably 1-2 shop hours, just want to make sure they press it on perfect otherwise will cause a shitload of headaches down the road.
