Turbo.
#34
I see this as working flawless...and that 500 dollar valve failing at some point
Didnt get a whole lot done today.
Got to the shop and just decided to do the heater lines instead of the oil pan, i want to have all the fittings and stuff ready so i can just get the drain done in one sitting, so that will most likely be this weekend.
I have the t in the 1 line for the throttle body bypass. The v6 32" radiators dont have the nipple like the v8s. I might get a longer hose for the bypass hose so i can move the hoses a little farther from the down pipe.
The bumper on these things is way to easy to pull off. Thanks GM.
Tomorrow. I think im taking a day off from it, but if not the intercooler will be mounted and the coldside will be ran.
#38
well you make one for under 100 bucks and ill try it
Need 1 more coupler. Turbo outlet is bigger then the t70's.
Also i cant find my freaking ev6 injector pigtails i ordered 2 months ago which pisses me off!
SO all i did tonight was bolt up the intercooler.
I still cant find the fittings for my oil drain, but i hope to by this weekend.
#39
Your taking about the oil pan right?
