TVS 2300 + other Goodies in an '04 SSS
Old 03-16-2015 | 09:45 AM
  #351
Vortec350ss's Avatar
hah! You don't have to send me your tune, I'm just curious to see your logs.
I hope you do beat my time. It'll give me motivation to make the changes I have wanted to for a long time.
Old 03-16-2015 | 11:00 AM
  #352
BigKID's Avatar
I like the heat exchanger. I have been looking at a few of the ZL1 upgrade offerings to use on mine. Nice to see how it fits in the front of a GMT800.
Old 03-16-2015 | 10:22 PM
  #353
L8ERBRO's Avatar
After we get her dialed in, I'll shoot you over a log file...just messin with ya Rob. I just got my wideband hooked into the HP Tuners so Zippy can see exactly what's going on. I'm sure we'll have her running great in a few days.
I'm guessing I'll run around 11.5 since I'm not changing out my 22's, I'll lose quite a bit right there alone.
Here's today's progress. Got everything hooked up and running, HOWEVER, did a test run only to find out my IAT's are actually higher than before. Usually mine are about 10 degrees over ambient just cruising down the road. My test drive was showing them to be about 25 degrees over ambient!
We currently have it set up out of SC to top of cooler, out of cooler at bottom next to temp sensor, to Ice Box, to pump, back to SC. My Brother thought we should hook into the top of the cooler and let gravity send it down to exit at the bottom. I thought to go into the bottom because the temp sensor is right next to it...plus it's a back to front cooler and the bottom inlet is on the back, top inlet exits the front toward the fans. Guess we'll try swapping them around to see if that fixes it. Does anyone know the correct way?
In-line shut off valve to drain the tank
Drains out right under the passengers' side mirror
Mounted the Varimax just behind the skid plate
plumbing closeup
Old 03-16-2015 | 10:25 PM
  #354
L8ERBRO's Avatar
http://vid1359.photobucket.com/album...316_172122.mp4
Old 03-17-2015 | 12:13 AM
  #355
You would see lower temps going from the pump to the IC, IC to the SC, SC to the tank, and pump below the tank. Your set up will show you benefits once you actually add ice to the tank where it will really cool off the water in there. As a DD that tank is just a hot box for the liquid to heat up as it waits to get pumped into the SC.
Old 03-17-2015 | 10:17 AM
  #356
GM1697's Avatar
looks good. I love superchargers on these trucks.
Old 03-17-2015 | 05:55 PM
  #357
BigKID's Avatar
Where is the intercooler inlet/outlet located on a TVS? It seems with the plumbing you described above, you have added some unnecessary length to the circuit by going from the icebox up front & down to the pump then back up to the IC. Even if the i/o is in the front of the lower manifold, you could benefit by putting the pump under the icebox. Those tight 90's at the heat exchange aren't helping flow any either.
Old 03-17-2015 | 08:40 PM
  #358
L8ERBRO's Avatar
Where is the intercooler inlet/outlet located on a TVS? It seems with the plumbing you described above, you have added some unnecessary length to the circuit by going from the icebox up front & down to the pump then back up to the IC. Even if the i/o is in the front of the lower manifold, you could benefit by putting the pump under the icebox. Those tight 90's at the heat exchange aren't helping flow any either. .
The strange part is, I just got home from a cruise; IAT's 91, ambient temp was 56. Popped the lid off the ice box and coolant was ice cold - felt colder than the air temp and flowing awesome
Old 03-17-2015 | 08:44 PM
  #359
L8ERBRO's Avatar
The inlet and outlet are located on the back of the SC near the firewall. I called Magnuson today and they told me the inlet and outlet are interchangeable too, meaning the flow direction doesn't matter.
Old 03-18-2015 | 05:30 AM
  #360
03sierraslt's Avatar
Ya, 35 above at cruise is too high. The stock Maggie setup will run lower then that.
I run, tank, pump, HX, blower then back to tank. For a all out track setup I would do different but I base mine on DD. Also there is such a thing as too much coolant flow.
As Maggie said, I've also ran the inlets and outlets both directions on different setups and there was no difference.
Quick Reply: TVS 2300 + other Goodies in an '04 SSS
