TVS 2300 + other Goodies in an '04 SSS
Old 06-11-2014 | 09:59 AM
  #51
mdwatts11's Avatar
Sounds and looks sick. Nice work.
Old 06-11-2014 | 11:43 PM
  #52
L8ERBRO's Avatar
Sounds Awesome. Have you driven it yet?
Took it for a couple of short test drives and found out my efans stopped working (They were working after my very first test drive) and now found out tonight my pump for the heat exchanger isn't working either!
Old 06-11-2014 | 11:44 PM
  #53
L8ERBRO's Avatar
Thanks bro!
Old 06-12-2014 | 12:25 AM
  #54
1FastBrick's Avatar
Custm2500's Rude Friend
Double check your connections on the Efan.
Same thing happened to me and the connector wasn't full locked in and backed out.
Old 06-12-2014 | 09:02 AM
  #55
Vortec350ss's Avatar
If both stopped working then it could be something as simple as a fuse... double check everything you tapped into.
Old 06-12-2014 | 10:22 AM
  #56
03sierraslt's Avatar
Make sure fan ground is tight. If it isn't then I bet your relays are burnt.
Old 06-12-2014 | 06:44 PM
  #57
L8ERBRO's Avatar
Problems solved...it was a rookie error on my part! I had hooked the efans onto the post in the main fuse box and it blew a 30amp fuse + I had the intercooler hooked to the other post which wasn't even live! Connected them both directly to the battery and now everything works fine. Also I wasn't getting full boost because the split loom for the IAT sensor to the blower was interfering with the actuator arm so I re-routed it. As I left my brother's shop, all 4 tires broke loose and got a little sideways
oh yeah, I ordered a 3.4" pulley from Magnuson the other day and I should have my crank pinning kit in the mail soon...should see 9 - 10psi I'm told
Funny story too on the way home from Firestone - was cruising on the highway in the fast lane doin around 70 and just as I got beside this lady in a Ford SUV, I stomped on it, passed her and signaled into her lane. What caught my eye was her swerving almost into the other lane and she looked like she was screaming at the top of her lungs while she was giving me the finger with both hands!
Old 06-12-2014 | 11:04 PM
  #58
Good stuff!! The pump for the Maggie does turn off, right? If it doesn't have a fuse to close the loop and let it know the vehicle is running or not it wouldn't stop.
I'm sure it's a beast. Do you know how much boost you're running currently? Only bigger and better things to come!! Let's see some videos!!
Old 06-12-2014 | 11:07 PM
  #59
L8ERBRO's Avatar
Your wish is my command!
https://www.youtube.com/watch?v=RI4V...=youtube_gdata
Just smoked this dude a few hours ago!
Not yet, they shipped me a BAR turbo gauge by mistake so I haven't hooked any of them up yet.
Old 06-12-2014 | 11:17 PM
  #60
Do you have a 2 bar MAP sensor? You should take some logs and post them up!!
I'd also love to see a nice launch and acceleration view of the gauges!
Glad you're loving it!!
Quick Reply: TVS 2300 + other Goodies in an '04 SSS
