TXsilverado 2.0 Build Thread
Old 09-16-2013, 10:16 AM
  #401
Resident Retard
BlackGMC's Avatar
I accidentally bought another 6.0 yesterday. Ly6 i believe. it needs new bearings but i couldnt pass the deal up. more money that could have gone towards finishing the truck i'm thinking it can possibly be a future low compression build
Your turning into Cody, stock piling parts...
Old 09-16-2013, 10:18 AM
  #402
TXsilverado's Avatar
except that mine eventually get used
i think a procharged 370 would fit under the hood of the s10 no problem. i'd like to learn how to tune a N/A and nitrous carbed engine before i dive into blow through carbs though.
Old 09-16-2013, 06:19 PM
  #403
oakley6575's Avatar
I've always wanted to tune a blow through carb set up. Sounds like a fun idea once this truck is running well
Old 09-16-2013, 09:34 PM
  #404
Slowest turbo build ever!
black00chev's Avatar
Great minds must think alike! I eventually want to do a 370"-408" procharger build. Seems like it would be a little easier than stuffing a blower or front mount turbo in there.
Old 10-04-2013, 01:02 AM
  #405
Resident Retard
BlackGMC's Avatar
any updates man?
Old 10-04-2013, 09:07 AM
  #406
got a few misc brake line fittings and a junk yard proportioning valve to get my brakes hooked back up. since i got rid of the ABS i had to find the right fittings to put 2 brake lines to 1 hole. NAPA finally got me figured out.
had to cut my throttle body spacer down 1/2 and my cleaner base seal CNC'd down 1 1/4" to make room for the hood. the TB spacer was to clear the booster line fitting on the back of the intake, and to simulate the 1/2" thickness of a NOS crosshair plate that will be there someday.
this weekend i'll be trying to figure out how to route my OEM hard brake lines away from the headers but keep them inside of the fender wells. should be fun. i decided to keep the metal fenderwells even though they are heavy as hell. it also made things easier. maybe a future project will be getting rid of them.
if i have time i'll get a new u-joint into the stock driveshaft, install it and fill the trans with fluid and start looking into the TCI transmission controller wiring/mounting. the stock driveshaft is a temp thing just because i want to be able to creep it around the block and look for bugs and leaks.
oh, my spring sliders are installed, but only vice gripped into place. trying to decide if i want to weld them in or just bolt them in. the welder is at my dads place, so i will probably just bolt them up.
here is where it sits. the air cleaner now sits 1.5" lower and the hood has room to shut now.
Old 10-04-2013, 09:11 AM
  #407
agh...that booster needs some painti'll probably get that done this weekend too.
Old 10-04-2013, 09:23 AM
  #408
skeet's Avatar
oh so close stew! looking good
hmm you gonna change your name to txs10
Old 10-04-2013, 09:29 AM
  #409
nah, TXsilverado is stuck.
Old 10-04-2013, 10:20 AM
  #410
Resident Retard
BlackGMC's Avatar
You live really close to smileys they have tons of brake parts/fittings. Honestly i would have just replaced all the lines with braided teflon lines. Go down to smileys and look at the different sections of brake lines they have.
Quick Reply: TXsilverado 2.0 Build Thread
