TXsilverado V 3.0
things are starting to roll along so i figure i would start a new thread and leave those last 2 "blown motor" threads to die.
V 1.0 - heads/cam/nitrous LS1 11.5@118
Status-blown into 10,000 pieces
V 2.0 - heads/cam/nitrous Lq9
Status- spun bearing in about 5 miles![Cry](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cry.gif)
V 3.0- heads/cam/nitrous 408
HKE standard iron 408
Callies Compstar 4340 4.000" Crankshaft
Wiseco Pistons w/ GFX Rings
Callies H-Beam Connecting Rods
ARP Main Studs
ACL race bearings
Melling HV oil pump
pat g 247/255 .632/.632 112+4 HUC
craig gallant stage 2 ls6 heads (2.02/1.57 valves) fully worked.
patriot gold springs
chromoly pushrods
ported fast 90mm with nick williams throttle body
kooks 1 7/8 stepped to 2" headsers with true dual 3" exhaust.
then all of the nitrous crap you stack on top of it. hopefully it does good.
ARP Main Studs
ACL race bearings
Melling HV oil pump
chromoly pushrods
Way to keep it going . It can be tough I have ha dv 4 motors in my truck so I feel ya . Even had to pull my 427 after it snapped a timing chain on the first crank . F'in sucked but look at it now
