Well here we go again...
#175
Well I did a little final assembly on the motor today, and some things on the trans
Final install on the motor:
Turbo manifold
Stock driver side manifold
Turbo
Oil feed block/fittings/line
Modified PT billet turbo drain block
Drain hose and all fittings
Valve covers with new gaskets
New TR6 plugs
New Taylor wires
Coil packs
Fresh filter
Oil dipstick
Final assembly on the trans:
Cleaned entire case
Degreased/pressure washed pan
Fresh filter
New pan gasket
Front cooler line adapter fitting (for trans hose system)
As of right now the motor is 100% ready to sit in the truck, and I'm waiting on FLT to build my rear cooler line fitting. The only setback was me breaking the temp sensor off in the head got a new one on the way as well as 3 brand new U-joints, including the conversion U joint for the front yoke.
Still TONS of little stuff to do.
Turbo manifold
Turbo
New TR6 plugs
New Taylor wires
Coil packs
Fresh filter
Oil dipstick
Cleaned entire case
Fresh filter
New pan gasket
