Well here we go again...
#301
How do I change this text
yeah, this has been the only drawback I've found with HPT.... I've found everything else to be MUCH easier. and better to work with...
and GMC, you need to stop arguing in my thread everyone knows that building a 5.7 is better than a 6L hahaha, it is a significant increase, but I disagree with it being the "best bang for the buck"
#307
not exactly, I just turned it around in the yard and backed it up where I was working on it, I've gotta re-shim the rear before the bed goes back on...
I put it in D, which defaults the 80E to 2nd gear (withouth proper tuning), and had to lean on the throttle a bit to make it move, I was like WTF now!!!! but then I remembered I've got a tune to try, and it should work until I get my seg swap back from HPT, the bad thing is, its a 1 bar tune, mine is set up for 2 bar OLSD so I'm just going to fail the MAF in the tune and be careful with it and setup the VE rich.... but once my tune comes back, I'll be in good shape. I just need to get it driving and get some break in miles on the new motor/converter/turbo, this should work for that.
