Well here we go again...
#313
Yea same with me, i travel for a living so i dont get much time to tinker with the settings. But i do get alot of time to read up on things.
One day it will all click.. Just take it slow.
#314
Resident Retard
not exactly, I just turned it around in the yard and backed it up where I was working on it, I've gotta re-shim the rear before the bed goes back on...
I put it in D, which defaults the 80E to 2nd gear (withouth proper tuning), and had to lean on the throttle a bit to make it move, I was like WTF now!!!! but then I remembered I've got a tune to try, and it should work until I get my seg swap back from HPT, the bad thing is, its a 1 bar tune, mine is set up for 2 bar OLSD so I'm just going to fail the MAF in the tune and be careful with it and setup the VE rich.... but once my tune comes back, I'll be in good shape. I just need to get it driving and get some break in miles on the new motor/converter/turbo, this should work for that.
Did you adjust the tune for the 2 bar map sensor? Assuming you left the sensor installed...
#315
The thing is with the tune I have, I'm going to have to license it to load it in the truck (2 credits) and then convert it to a 2 bar OLSD OS (2 credits)... when Ive already licensed a tune and converted it to 2 bar OLSD for the truck once ( 4 credits total again) so.... in ONE truck, I'd have 8 credits tied up total.... .the software only came with 8 so anything else, I'll have to purchase more credits to do ($50 ea)
-that being said, I'm going to just license the tune that Dusty put together for me and leave it one bar and just set it to default and go rich if it gets into boost (which I can already tell is going to happen very quickly) and just generally be careful with it.... until my tune comes back from HPT, then I can load it, have my 2 bar OLSD stuff back, and be on my merry way...
get all that?? cause I didnt
