Well here we go again...
Old 06-15-2009, 06:56 PM
  #361
GMCtrk's Avatar
Where does that oil feed line come from?
Old 06-15-2009, 06:58 PM
  #362
Hunt&Fisherator
silver-mod-o's Avatar
and for those wondering... YES, I can open the wastegate with the truck sitting still
so far its made 6psi in the grass on the brakes where it begins to open... and the wastegate is fully open at about 9-10psi
Old 06-15-2009, 06:59 PM
  #363
Hunt&Fisherator
theres a billet block on the oil bypass just above the filter.... with a 1/8NPT to-4AN 90* fitting, then it comes up, and across under the TB to the guage, and into the turbo...
Old 06-15-2009, 07:03 PM
  #364
GMCtrk's Avatar
Is that pretty much where everyone gets the oil from?
Where are you returning the oil at? Drilled a hole in the passenger's side oil pan? Is just returning it to the passenger side head thru the oil fill a viable option?
Old 06-15-2009, 07:05 PM
  #365
JakeBrakeIH's Avatar
I would def. be interested to hear a sounds clip...you dont really see any videos of trucks exhaust clips with turbos, just dyno vids...seeing my 2000 is like urs, Im dont really care how loud it is and was planning on just running straight pipe...unless ur vid changes my mind
  #366
charcold-bowtie's Avatar
most peoples are something like this.
pressure.
return.
Old 06-15-2009, 07:08 PM
  #367
I will be getting my oil pressure from there and draining into the passenger side of the oil pan...
Old 06-15-2009, 07:09 PM
  #368
GMCtrk's Avatar
Im assuming you gotta pull the pan off to tap that return fitting, right?
Old 06-15-2009, 07:11 PM
  #369
no. I didnt. no motor trouble thus far. I will note the front of the truck was on jackstands and oil was coming out of the hole when I drilled it. A little messy but didnt pull the pan.
note shitty 60e in background lol.
Old 06-15-2009, 07:12 PM
  #370
GMCtrk's Avatar
How do you keep from metal shavings from getting in the pan???
Quick Reply: Well here we go again...
