Well here we go again...
#83
the log/turbo comes out fine with the motor, I leave both manifolds on when it comes in/out. makes it so thats one less thing to deal with under the hood where theres less room. I put all the oil lines together out of the truck too, if there are issues, I just have to adjust rather than start from scratch.
#84
Thanks!! I took a lot of time/patience getting it to look like what you see. I hope to have it all in one piece and maybe fired up in about 3 weeks. now that I've got the trans in-hand, I'm going to knock out the crossmember and pull measurements for the driveshaft. since I got the older style 80E, all my trans cooler stuff will swap over. fittings, hoses and 30K cooler.
#90
After discovering my rear suspension issues (two broken leaf springs) I've had to stop powerplant work and shift my attention to the rear of the truck.
I started setting some of the back exhaust section in place, and I like the looks of it just a big ole raw steel 4" tip where the stock Duramaxes exit at a 45* angle out the back. I will probably end up trimming it back but I'm curious to see what its going to sound like with a "full" exhaust system on it for once...
I'm also selling this 80E for a later model trans. Its up for grabs now cheap if someone wants needs
