Whistle pig build
#115
Currently out of the country at the moment till the beginning of the year so I figured I'd throw together a little update. Trucks all tucked in for winter but I've started getting everything together to finish wiring in the trans brake and 2 step, I have two switches available on the shifter but I'd like to run both the TB & 2step on the same switch and wire the smooth stage into the other switch. Still trying to get a solid answer on wether or not to use a relay on the TB & 2 step switch, some say it causes delay. Also got an eboost2 from turbo smart to control the jgs wastegate I'm using. Unfortunately I've heard a few horror stories from the cubby hole gauge pod that TTS makes(customer service not the product) so I opted for the Cubbycam pod to house the wastegate gauge, once I get home I'll get some pictures for anyone wanting to run the same. Still on the hunt for a 9in so I can get rid of this 10 bolt, might end up going the Moser route thats already set up. I know I've said before id like to have the truck 4 linked but I think I may run caltracs just to get some passes on this thing this year. Later on if it's necessary I'll make the change. Hope everyone has a great Christmas and New Year hopefully ill have made some good progress by the time I check back in.
#119
