Whistle pig build
Old 06-18-2020 | 10:41 PM
  #241
ironcityboom's Avatar
Originally Posted by ALL ULL C
I really like this build and it scares the hell of out me too. I've been wanting to at a minimum take the bed off my truck and have the rear frame blasted/cleaned up but then I think to myself how much more would it take to remove the cab and front clip. I'll be stripping alot of the OEM engine wiring out in order to run a Holley as well but want to keep the radio, A/C, cruise, and add power windows/locks all on the factory ECM if I can.
Hell of a job and I may be asking some questions as I like what you've done.
Thanks man! I know it seems daunting man but it’s absolutely worth it. I initially did the same when my bed was off but it’s too damn hard and my ocd couldn’t handle only half the truck being done. If you have any questions don’t hesitate to ask.
Originally Posted by BigKID
Nice work on the frame and I am jealous of the space you have to work. I do have a few questions though...
What are the particulars on the control arms? The pics look like the lower ball joints are canted to provide a lot of positive caster. What ball joints are to be used with them for the g-body spindles? Could these arms be used with the truck spindles with a different ball joint?
Why did you cut out the middle cross member? Any intentions to reinforce it there? Seems like that would allow for more frame twist. What are the plans for the fuel tank now that cross member is gone?
I had the arms built specifically for gbody spindles and from what I understand that’s the only spindle these are intended for. I honestly don’t really have specifics on the ball joint brand or part numbers they use It’s just what they include with the arms.
As for the cross members I’m not worried about anything. I’m sure the two for the fuel tank straps added some rigidity but not enough for me to want to keep them. And I have a bed mounted fuel cell so that made the decision to cut the cross members out even easier.
Old 07-10-2020 | 10:53 PM
  #242
Making a little more progress, finally got the hot side in and mocked up. Upgraded to a T6 while I was at it. Hopefully start getting the cold side figured out, should be pretty simple since I'm going not Intercooled. Waiting on my torque converter to come back from having gone through and cleaned up then I can throw the trans back in real quick in and get the cab swapped over. Brake lines are next but they'll be pretty simple running -3an line. Already have the rear line to the axle in but I'll wait till the cab is back on to measure from the master cylinder accurately. If anyone has any recommendations for a radiator builder I'm all ears, looking at Ron Davis and a couple others but I want something pretty specific so I don't want just any off the shelf rad.
The following 4 users liked this post by ironcityboom:
ALL ULL C (07-12-2020), dantheman1540 (10-20-2020), ILuvJDM (08-07-2020), tjmath (07-10-2020)
Old 07-11-2020 | 01:34 PM
  #243
Atomic's Avatar
I have a gauge for that
I had PRC build my radiator, big heat exchanger, and fan shroud and they did a very good job and werent too expensive. It was custom made to my specs.
ALL ULL C (07-13-2020)
Old 07-11-2020 | 03:11 PM
  #244
tjmath's Avatar
I love all the little touches on this build. Looks incredible man. Can't wait to see it all back together.
Old 07-11-2020 | 09:46 PM
  #245
03sierraslt's Avatar
It’s coming together.
Old 07-11-2020 | 11:18 PM
  #246
Thanks man! I'll check them out!
Thanks! I appreciate it! The little stuff is what's taking me so long to get this damn thing back together haha
Slowwwwly
Old 10-19-2020 | 10:11 PM
  #247
Time for another update made a ton of progress since the last post. Cab and bed are on, trimmed fenders, and got the rad support back from powder coat. Finally got my wheels in and they were definitely worth the wait! Waiting on shocks, I originally wanted to go with Viking shocks however I called and they were worried with the ride height of the truck and concerned with the valving, same story from strange, finally ended up talking with the guys over at Afco and they're certain they have what I need so we're waiting for those to get here( hopefully by the end of this week) and we'll finally have a roller. Also plan on getting this thing on the street once it's done so I'm in the process of getting the lights wired into the painless switchboard. Wasn't a big fan of the push lock boost lines so decided to build some hard lines, pretty happy so far with how everything is turning out basically just need a drive shaft and radiator and she'll be back to moving under her own power! Just in time for winter haha
The following 3 users liked this post by ironcityboom:
ALL ULL C (10-20-2020), dantheman1540 (10-20-2020), SlowHoe (04-14-2021)
Old 10-20-2020 | 12:47 AM
  #248
RedXray's Avatar
100% Redneck
Awesome work man... I'm so jelly
Old 10-20-2020 | 06:44 AM
  #249
dantheman1540's Avatar
Gorgeous build.
Old 10-20-2020 | 12:34 PM
  #250
tjmath's Avatar
Those wheels are ******* dope dude. And I concur with the above statement... I am also super jelly.
Quick Reply: Whistle pig build
