damn tundra spanked me!!
#41
That track has to be 600'....a 9.3 1/8th is about a 14.5 in the 1/4 and your mph 71 puts you at 88mph in the 1/4...there is no way you are running that in the 1/8th with a 2.1 60ft.
#44
i tried friday night to run, but i couldnt hook. i pulled the spare tire and tailgate, and i spun the first 100'...... i never got a chance to spray it.
i just ordered a set of 17" aluminum wheels and put some hooker LT's on...sounds beastly!!
i probably wont run again until i get the locker and gears in. the tires are 275/60r17 that i ordered.
#47
With a good tune, 9.5" 3000+ converter, 4.10/locker, & tires, nitrous vs. nitrous you will be putting that tundra in it's place (rear view mirror).
#48
i just got the new 17" rims/tires in that i ordered...so that should help a lot!! gears and posi are on the way, i will stick with this converter for now. it was from RedStarPerformance, and looks like a stock unit....but its all new inside.....i wanted to avoid warranty issues so i asked for something with a stock look....but now i think i have voided the warranty with these long tubes and no cats.
its you guys fault, making me want to go faster and faster. if i cant pull at least a 1.9 60ft with this verter and 17" tires/ 3.73 gears....then i will swap to a smaller OD verter with a higher stall speed.
