07 Tahoe Wheels & Backspacing
Does anyone know what the correct backspacing is for 22" X 9.5" wheels? I see them listed with like +40mm and +12mm? I don't understand that stuff. I assume the +40mm would stick out, so the +12mm is what I would be looking for? I DO NOT want the wheels to stick out past the fender.
This would be on an 07 NNBS Tahoe, which I would think is the same as all the 99 & up NBS?
TIA,
S.C.
TIA,
S.C.
The more offset the more the wheels tuck into the fenders. You will want to go with a +40 if you don't want them to stick out.
And the 07+ trucks/suvs use a larger offset than the pre 07s to tuck. A lot of the pre 07 guys are actually using the cast 07+ wheels since they are cheaper than billets and still tuck.
mitchellmade
09-27-2015 08:25 PM
