'08 sierra denali lowering concerns
I want to get a Mcgaughy's 2/4 drop with rear air lift helper springs. The truck has the stock 20's on it now but I eventually plan for 22's w/ a 40 or 45 series tire. Should I worry about scraping the somewhat low front fascia on the truck?
BTW know of any nice 22" wheels w/ a black, gray, or gun metal center w/ a polished lip?
Yeah, this is probably the wrong area for this question, but IMO you should have zero problems running a 2-4 on an 08. They are considerably higher than the previous generation and those have no problems with that amount of drop.
And for Black/Polished, I would go with these: Foose Speedster 6
you have to be very careful of the kit you put on this truck. you cannot lower this truck to much because you'll run in drive train problems. if you lower the truck to much, at high speeds you'll get vibration because of the awd. i'm still doing research on this because i wanna lower my 09 sierra denali with 24'' on there, standby!!
chacho44
14
07-25-2015 01:47 PM
