17x11's and 17x8.5's
Old 02-26-2007, 02:12 PM
YenkoST's Avatar
oh ok.....you wouldn't need them to tuck then. Unless you go lower than a 2/4. A 2/4, just don't go any higher than a 29" tall tire and you'll be fine. Otherwise, roll your fender lips. He is supposed to be getting some pics to me by the way.
Old 02-26-2007, 03:11 PM
LS1GMCTruck's Avatar
Question Rolling Fenders...
Hows everyone rolling the inside rear fender lips? Best method?
Old 02-26-2007, 04:45 PM
YenkoST's Avatar
If you are a DIY, then cut the lip into 3" sections(making sure you having about an 1/8" before you hit the fender lip and take a hammer and knock them back)......be careful so that you don't dent your fender. Also, after your done, paint the raw metal with something so that it doesn't rust.
Old 03-01-2007, 06:26 AM
stick-shift's Avatar
I jusy want to make sure they dont look like *** sticking ut the side of the truck
Old 03-01-2007, 11:08 AM
YenkoST's Avatar
dependent on the backspacing but with about 5" backspacing, you'll have about 1 or so" sticking out.
Old 03-01-2007, 12:54 PM
lawson4450's Avatar
on my truck the rear tires tuck on one side and sit even with the fender on the other side my rear end is off just a little it took me a long time to notice it but i can see it now and its annoying
Old 03-03-2007, 01:28 PM
Thats the worse thing,put your new rims on and one sid esticks out further!Drives me up the wall to,Thinking about when if it does it on this one,I'm going with a panhard bar,it will make everything even then!The old c10's had them from the factory
Old 03-19-2007, 11:21 PM
YenkoST's Avatar
Finally got your pic. You can see where its rubbing on the leaf springs. That's with a 315/35 tire.
http://i77.photobucket.com/albums/j7...nstruck017.jpg
dantheman1540
08-05-2015 05:23 PM
Blackbird-WS6
11-22-2013 11:29 AM
Dirty 30
01-24-2013 04:25 PM
62nalide
09-12-2012 01:27 AM
68LS1WANNABE
01-24-2010 09:17 AM
Quick Reply: 17x11's and 17x8.5's
