2 / 2 Questions
2 / 2 Questions
If I use 2" drop springs on the front and 2" drop shackles (or blocks) on the rear...('00 Silvy) will the front end need any adjustments??
Would this look o.k. with stock wheels / tires (for now ?)
Any pics of 2/2 drops ??
if your droping a ne w silverado you need hangers and shackles in the rear. you will need a frontend alignment nomatter what!!!
i did a 1/2 drop on mine and it sits up just right with the stocker or the 20's... I think if you go 2/2 then you would be able to tell quite abit that it is lower in the front...
a guy at work has a 2/2 drop on his truck and to me it doesn't look right. the rear has too much fender gap and the front wheels tuck. i wish i had a way to take a pic of it for you to see.
this truck here is dropped 2 inches in the front and rear.
https://www.performancetrucks.net/fo...d.php?t=345357
