2/4 drop
2/4 drop
I am contemplating going back to stock wheels and tires with the drop or keeping my 20's on. does anyone have pictures. I am kind of worried my tires might be to tall. I have 275/55/r20 goodyear ls tires. thanks
Baltimore Whore
well i doubt that they will be too tall.i have a 3/4 drop on my truck and have 275 45 20 and is not even close to hitting.i am going to do a flip kit to get it lower
I have DJM 2/4 with 265/50/20. The back tire are way clear of every thing. The front if you hit the bump stop the tire will just touch the inner fender well. Also when I turn my tires all the way left or right the tire will rub on the sway bar. . My tires are 10.433 wide by 30.400 tall yours are 10.800 wide by 31.909 tall. So as long as you have the right offset rims you will be fine. Make sure you don't have any screws sticking out of you front fender wells.
I am running the 5.5 backspacing. I am working on getting some stock wheels incase I have any problems. thanks. I hate my tirees their jsut to tall.
I have a 2/4 drop with 22s and theyre 31.6" tall and my backspacing is 5.7, I dont have any problems rubbing when I turn but when I hit a bump, the front rubbed but now I have my wells cut out and I have no problems
I am hopeing that's the only time, atleast until I can afford to put new tires on, then I will go down to 45 sidewall. how big of a tire can you fit on the front and back with 8.5 inch wide rim with the drop.
