2003 Tail lights on 2000 Truck
Old 11-29-2003, 02:16 PM
Cuz I AM a BADMOFO
BADMOFO's Avatar
Default 2003 Tail lights on 2000 Truck
Will these lights just bolt right on, or is there some wiring or harness altercations necessary??
Old 11-29-2003, 02:24 PM
CHAGO's Avatar
The '03s have a different wiring harness that you'll need to convert
Old 11-29-2003, 02:33 PM
Cuz I AM a BADMOFO
BADMOFO's Avatar
And how do you do that??
Old 11-29-2003, 02:35 PM
Cuz I AM a BADMOFO
BADMOFO's Avatar
Do you mean just different ends?? Or are there more or less bulbs than the 2000's?
Old 11-29-2003, 02:49 PM
CHAGO's Avatar
Its a different wiring harness you have to put in there.
Not sure about the bulbs, I assume there's the same count of bulbs, but dont quote me on that.
Old 11-29-2003, 04:47 PM
Formerly one92rs
one03sierra's Avatar
the 2003 lights have more bulbs in them . you have to get the wiring harness for the 2003
Old 11-29-2003, 08:33 PM
Cuz I AM a BADMOFO
BADMOFO's Avatar
I just got the lights off Ebay, and of course, harnesses were NOT included!!! Where can I get the harnesses and what are they gonna cost me?? Any ideas.
Old 11-30-2003, 12:19 AM
Formerly one92rs
Talking
hey buddy ask tbyrne or look at his sight. he is a sponser and i believe he of fers them
Old 11-30-2003, 12:22 AM
blownerator
BlownChevy's Avatar
Got mine off of ebay a while back, came with the harness and everything!
I could check with the body shop next door to us if you want. e-mail me info@projectrwear.com
Old 12-02-2003, 07:08 AM
Tech Fanatic
03GMC2500HD's Avatar
I installed the 03 lights on my 03 GMC and they didn't have the harness. It is really simple to add the extra light the 03 tails have. Go to AutoZone and pick up a couple license plate sockets that hold the 194 bulbs, pack of 194 bulbs and some quick connectors. Locate the "lights only" wire on your existing harness and use the quick connector to splice in the 194 socket. You will have to trim a couple tabs off the socket but it is very simple and a pocket knife will do. All that is left is to open plug the sockets into the tails and your ready. You may have to rotate the factory sockets a little to match up with the tails and you will probably have to modify a hole or two for the factory sockets to pop in but the whole thing takes about 10 min for each light and works great. Since the 03 harness is not available from GM, $10 at AutoZone and 20 min of work isn't too bad!
Quick Reply: 2003 Tail lights on 2000 Truck
